Question about Kodak Cameras
I have 4 rols of Kodachrome 8mm double K459 25ft Film that was never processed. Is there aney ware this can still be done? I realise they may be spoiled, but there from my child hood at US Fort Sill Ok. 1962 to 1964 thanks Lee Ashcraft lashcraft_7968@yakoo.com 740-745-5992
  • 356 Answers
There's very little chance that it has survived if it wasn't processed. If they're highly important to you, it may be worth the chance.
Very few places still process this kind of film. You may want to try the following company to see if they will (I don't see your specific film listed, but they process similar ones so you may want to contact them).
http://www.rockymountainfilm.com/oldfilm.htm
Please leave feedback if this was helpful. Thanks.
Posted on Apr 04, 2011
How many feet in 8mm
no feet in 8mm
roughly 8mm is 1/3 of an inch or 3/8 "
Oct 23, 2017 | Video Cameras
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
How do transfer 8mm film to dvd yourself?
If you have time, you would project your film onto a screen, and use a video camera to capture the show. Likely, you will get rather poor quality.
When professionally done, each frame is captured separately and made into a video. Better quality, but it takes a bunch of equipment that's expensive.
Oct 06, 2015 | Bell & Howell 10,000 Ft 8 Mm, Super 8,16mm...
How Much Resolution is on Film?
Actual film resolution is dependent on the size of the grains of the light-sensitive emulsion used to coat the film. Generally speaking, the larger the grains, the 'faster' the film will be, meaning that it will react to light more quickly and you can take pictures in conditions were lower light levels are present.
When I was using 35mm film cameras, I could use Kodak Tri-X film with an ISO rating of 400 to take low light pictures in black and white. The grain of the photos was not the best, but I could get pictures that might otherwise be difficult to take successfully.
The 'gold standard' for color pictures was Kodachrome slide film, with an ISO rating of 25. It had a very small grain color emulsion, which allowed very fine detail to be recorded by the film, but the slow reaction speed of the color emulsion to light meant the objects needed to be lit by the sun or high-intensity artificial light to photography correctly.
Jul 11, 2015 | Computers & Internet
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
I am scanning Kodachrome Transparency's and I am struggling to capture the full image on some slides. Some are scanning fine, others are chopping off an edge? Any ideas?
There are manual position settings you can use.
Make sure the film is placed correctly in the film holder and the film holder is properly
positioned on the document table.
Switch to Home Mode or Professional Mode, and preview with the Normal Preview. In the
Preview window, create marquees on the area you want to scan, and then scan.
Also...if all else fails
Try rotating the slide 90 degrees, you can always rotate the saved image afterwards.Ditto flipping over to the other side
.I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Epson Perfection V200 Flatbed Scanner
Developing a film without opening the camera
Am i right in thinking the keystone is a old 8mm movie camera? Never had any experience with movie cameras, or developing their film- I'm goin to assume its like 35mm developing, apologies if this is completly useless advice.
I'm fairly certain you will not be able to develop film in camera (camera will end up pretty wet). If the problem you have is actually getting film out o the camera I'd suggest a changing bag- basically a light tight bag that you put the camera in with your developing tin (if your home developing) or canister if your using a lab, you then have to put your hands inside 2 holes either side and transfer your film from camera to developing container- blind.
I'd advise doing a couple practice runs first with some old unused film just to get the hang of it- it can be tricky.
Again I have no experience with 8mm film processing but I'd imagine the principles are similiar.
You can get hold of changing bags from most photographic retailers, and always follow instructions that came with your film.
Nov 05, 2009 | Cameras
Film advance
I bought a seagull 4a-105 camera and the film advance never seems to be consistent. Often times the frame counter numbers are not centered in the
viewing bubble. When I go to have the film processed, I have had as many as six to seven frames either double exposed, or no exposure in the frame. The
best that I have managed out of 12 frames is 8 frames done correctly. I followed the directions and threaded the film to where the arrows align with the marks, but still the problem persists. Is the film winder the culprit? If so, how can I repair
it? The camera cost me $217 new, and I can't justify spending $200 to repair it when I could buy a used Yashica online. Any help or advice is appreciated.
Apr 21, 2008 | Shanghai Seagull 4A-105 Medium Format...
Cameras Logo
96 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
