Question about Samsung SGH-T339 Cellular Phone
ARP no response W003.1 cannot connect to wireless
What Are the Aging Time and Aging Mechanism of ARP Entries?
The default aging time of ARP entries is 20 minutes. You can run the arp expire-time command to change the aging time.
You can also change the number of ARP probes by running the arp detect-times command. The default number of ARP probes is 3.
When the aging time of an ARP entry expires, the device sends a probe packet to the corresponding IP address every 5 seconds. If the device does not receive any response after the specified number of probes, it deletes the ARP entry.
For example, the aging time of ARP entries is set to 60s and the number of ARP probes is set to 6.
After 60s since an ARP entry is generated, the device sends an ARP probe every 5s. If the device does not receive any response after sending six probes, it deletes the ARP entry. Therefore, the actual aging time of the ARP entry is (60 + 6 x 5) = 90s.
NOTE:
For V100R002 version, the S2700/S3700/S5700/S6700 supports the 1/2 probe time and 3/4 probe time. The numbers of probes on the two time points are both 3 and cannot be changed. For example, if the aging time is 20 minutes (1200s) and the number of ARP probes is 6, the SS2700/S3700/S5700/S6700 sends three ARP probes at an interval of 5s after 10 minutes. After 15 minutes, the S2700/S3700/S5700/S6700 also sends three ARP probes at an interval of 5s. After 20 minutes, the S2700/S3700/S5700/S6700 sends six ARP probes at an interval of 5s. If the S2700/S3700/S5700/S6700 does not receive any response, it deletes the ARP entry
Jul 29, 2016 | Computers & Internet
When a User Connects to Devices Such as a Server Through a Switch, the Connection Speed Is Slow and Packet Loss Occurs Sometimes. Why?
In SV100R001 and SV100R002, packets are discarded when a large number of ARP entries exist on the switch, ARP hash conflicts occur on the chassis switch(such as S3700-52P-EI-24S-AC), entries fail to be delivered, or traffic is slowly forwarded in software forwarding mode. In this case, services are affected. In SV100R006 or later versions, ARP entries are delivered to the defip table after ARP hash conflicts occur. The problem of packet loss is resolved.
Jul 27, 2016 | Computers & Internet
Iomega mdhd 360 n
The following may help:
You can either use the management software: Iomega Discovery Tool Home : Read First
or
Instructions to Direct Connect to NAS:
Unplug the NAS from the router
Unplug the pc from the router (if the pc is wireless, disable wireless)
Using Ethernet Cable, plug the NAS directly into the pc with no other devices attached.
Restart the NAS and wait for it to boot COMPLETELY 100%
The NAS will request an address from the PC which will be an APIPA address (this is a 169. address)
Open up your Start Menu and type in CMD in the search bar and select the CMD program.
Type in "arp -a" in the cmd prompt
The first time you use the arp -a in a cmd prompt, it gives you the 169.x.x.x address of "The PC"
You may have to arp -a twice to get the NAS address.
The second time you use the arp -a I will get another APIPA address in the 169.x.x.x address
Take the new address and use it in the web browser just like normal to access the device
Mar 22, 2014 | Computers & Internet
LAN cannot see on arp -a command prompt
sometimes you have to ping the device before an ARP request will be sent. If you are trying to find out the IP address, use a network scanner. Some wireless utilities will actually give you the IP address of the AP you are connected to also. If all else fails, factory reset the router and you will then know the IP address.
May 29, 2012 | Linksys Wireless-N WRT150N Router
When i open my internet it scroll very slow so i open my LAN connection using Realtek RTL8168D(P)/8111D(P)PCI-EGigabit Ethernet NIC and open its'properties and click the box repair and suddenly a...
Hi
The Address Resolution Protocol (ARP) is very crucial for TCP/IP network communication. If you begin to notice network connectivity problems such as particular web pages not loading or not being able to ping certain IP addresses then clearing your ARP cache is a good place to start.The TCP/IP ARP Command component provides the functionality to add, delete, or display the IP address for Media Access Control (MAC) address translation.
To flush/Delete the ARP cache in windows 7/Vista/XP/2000/Server 2003/2008 follow this procedure
Click on Start->Run-> type the following command click ok
netsh interface ip delete arpcache
Dynamic ARP cache entries update persist for 2-20 minutes depending on the system.
Windows 2003 Server = 10 minutes
Windows 2000 professional/Server = 10 minutes
Windows XP = 2 minutes
Solaris = 5 minutes
Delete IP address using arp command
arp -d <ip address>
Example
arp -d 10.1.1.2
Display arp table
arp -a
Add static entry to ARP table
arp -s <ip address> <mac address>
Example
arp -s 157.55.85.212 00-aa-00-62-c6-09
Jun 21, 2011 | Nvidia Computers & Internet
Wireless
go to command prompt
star->run
type cmd
then type in c:\arp -a
and it will show your address connect in your network
then check the physical address if belongs to your device
if not familiar with the physical address then someone is hijacking your connection
Nov 19, 2008 | Siemens Efficient Networks SpeedStream...
Wireless problem
Changing MAC address of a router is usally not nessicary and can cause this issue. ARP (Address Resoution Proticol) maps the IP addresses of ever device on the network to their MAC addresses. To make this process more efficent computers cache (store) this information for quicker retrival. So once your computer has connected to your router it stores it's MAC address. When it trys to connect again, and you've changed the MAC address the computer will still try to connect t a device with the old MAC address which now doesn't exist.
If you find it nessicary to change the MAC address of the router you'll want to clear the ARP cache on the machines that connect to it. To do so type "netsh interface ip delete arpcache" from a command line.
Feb 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
Samsung SGH-T339 Cellular Phone Logo
91 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
