The system seems to be working however no sound from speakers.Recently had disc stuck & was taken to repairer to remove since then has had the no sound issue. Any help with this greatly appreciated. Thanks Terry
    Brigadier General:
  • 8,546 Answers
You might want to run that by the 'repairer' andask what he did.
Or look at all the controls and indicators for onethat is mis-set.
Posted on Apr 04, 2011
  • terry_mar402 Apr 04, 2011
    Thanks I will check all the controls and see how I go. Unfortunately I have moved to another town so not near the repairer that removed the stuck disc to return & ask.
    Cheers Terry
I have a jvc kdg431 radio/disc player. recently the speakers stopped working intermittently. They have now stopped alltogether. Ihave looked at the fuse on the back of the unit & that is ok .
I have had this problem before. The first thing you have to do is fade the deck all the way to the rear. Now turn the deck off and than back on see if you have sound now? IF not fade the deck all the way to the front and turn the deck off and than back on see if you have sound now? What you are doing is checking for a bad speaker because if you have a grounded speaker it will shut off the decks internal amp. You can do this though out the left and right as well to find if is a that. Now if nothing you do helps you might have to replace the deck. IF you want to get carried away you can check the OHM,s on each speaker and check each speaker to a ground with an OHM meter and if you have any speaker that shows a speaker lead that shows a ground start chasing that wire and see if it has a screw through it. Go all the way to the speaker. You will probably find a bad speaker that has shut off you system ?
Jan 01, 2015 | JVC Car Audio & Video
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
I recently got a new computer & it has windows
If there is not a dedicated port for the sub, you are out of luck. Unless - the MLI sub can serve as the splitter
Jul 24, 2009 | MidiLand MLi 450 Computer Speakers
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Repair of Z560 amplifier
try fixing its amps by simple reheating it. if still doesnt work try replacing its parts... it is certain that it has a prob on the amps.
Oct 14, 2007 | Logitech Z-560 Computer Speakers
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
14 people viewed this question
 Grubhead
Grubhead
