Question about Bell Sports Bell Airstrike 800 Frame Pump
Bell strike bicyke air pump has a piece the tire air tube should fit but it just slides all around and does not fit, does this product have a recall? I should return it I guess.
How do I change tire of Toro Proline 44?
the fronts on these walk behinds are solid , i replaced one of mine with a scoffold caster that i had worked great , the rears are tube'd tires , you can get the tube replaced with out even taking tire off the machine , jack up side that your working on , let all the air out of tube (remove valve core ) i use a old hvac vac pump to suck every last bit of air from tube , break tire bead seal , push with piece of wood !! after you get entire bead down , work tube from around the bead seal to you get it all out , push stem down hole then its out , reverse to reinstall new tube any lawn shop sells them inthat size , add air to new tube till beads seals , then let it out to correct pressure (i use 12 psi) let jack down and off you go !!
Sep 30, 2014 | Garden
How to use a Schwinn Aluminum Frame Pump to pump up a bike tire??? I have it on the tire but the air comes out of the top piece instead of the part hooked to the tire!
THE TRICK TO SWITCHING OVER THE OUTLET FOR THE PUMPED AIR IS BACK PRESSURE. IF WHAT YOU ARE FILLING IS COMPLETELY FLAT, BLOW INTO THE FITTING YOU WANT TO USE AND IT WILL SWITCH OVER.
Sep 05, 2011 | Schwinn Bicycle Aluminum Frame Pump
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
Mar 20, 2011 | Airstrike Bell 1800 Floor Bike Pump
Schwinn mini pump for schrader and presto bike valves. cant get it to work. its only lettign the air out of the bike tire not into it. it has a diagram and 3 different parts but we dont know how to put...
Look at this so you have a handle on what the shrader valve looks like.
Put the parts together as follows: insert the hard plastic piece so it protrudes to depress the center valve in the tube; place the round rubber piece over the frist piece wih the large opening facing outward toward the tube; snugly screw on the cap to compress the first two pieces.
Jun 12, 2010 | Kenda Tires Tubes Key Chain Bmx Bike...
Air pump fits on front tire valve, but not on rear. won't catch valve stem...both are schrader valves. help???
The tube has rotated on the rim. You will need to let the air out of the inner tube then "break the bead " on the tire to free the tire from the rim. With the tire edges now separated from the rim you can squeeze the tire and tube together as you turn the tire in the direction needed to rotate the inner tube back into alignment with the hole in the rim. Now refill the inner tube to 5 lbs less than the max pressure noted on the sidewall of the tire. Low tire pressure is what allowed the tire to spin on the rim, taking the tube with it.
A “very helpful” rating for this answer? Thanks!
Jun 15, 2009 | 2001 Suzuki DR-Z 250
Push bike tire
Inner tubes commonly lose air when stored for as little as a couple of months and quicker when cold. They also tend to dry out and leak as fast as you can pump. Replacement tubes are available at bike shops and even less than $6.00 bucks at Wal-Mart.
To replace(The long version,cause the short version not good):
Remove wheel from bike, trike, trailer, etc. and deflate tube completely. You will need 2 box end wrenches (the ones with the closed ends, because these are not sharp). Insert box end of wrenches next to each other between rim and and one wall of tire, now pry the wrenches back so as to pry one wall of tire to the outside of rim, now alternatingwrenches, slide wrenches away from each other to slowly walk one wall of tire outside of the rim, reach in and grasp old tube and pull it out. Now straight new tube out remove plastic fill cap(put cap in your pocket), reach in and insert filler into hole in rim, now working your way around with your fingers to push tube up into tire(carefull not to let it get twisted), now put cap back on tube so you don't loose the filler, now work your way around with your fingers to push tire back into rim, you may need to use the box end of the wrenchto help pry the last bit of tire back in(Just don't pinch the tube between wrench and rim while doing this, lest you now have a new hole to fix), now grasp filler so you don't loose it, add air to amount shown on tire, and RIDE ON!
Apr 25, 2009 | Cycling
Bicycle tire pump won't pump.
If you can? unscrew the two pieces of the pump clean and oil it. W/D40 works pretty good.
Apr 24, 2009 | Airstrike Bell 800 Frame Mount Bicycle...
Unusal valve stem on the tire tubes how do I pump?
ok mate you have to go to a bike shop and buy a the newer tubes the one your daughter has is really old and they dont make them any more so just go to a bike shop and ask for a bike tube and then ther you go also if ya need any help putting it on just give us a bell. and dont forget to rate me .
Mar 28, 2009 | Kettler Scoot Training Bike
How to repair a flat tire?
hi!
to find the hole, try to fill the tire with air, and put it on a shallow water were it's enough for you to see the bumbles that come out from the tire.
to repair a flat tire, take out the interior of tire and if you happen to see the location of the hole try to find an unused rubber and cover the hole with that rubber and glue it with a quick drying glue... (this is a non-professional work)
Oct 29, 2008 | Bell Sports #1002016 26" Mountain Bike...
BELL JOGGER HANDLE
(800) 456-2355 is the customer service number for Bell. Unfortunately, the stroller only has a 1 year warranty and no replacement parts. I won't be buying their products again.
Oct 29, 2007 | Bell Sports Scout Jogger
Bell Sports Bell Airstrike 800 Frame Pump Logo
46 people viewed this question
Top Bell Sports Cycling Experts
Eric Hidle
Level 1 Expert
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
