Question about Echo Garden
The starter string does not retract after being pulled on my Echo weed trimmer
  • 577 Answers
Spring probably broke for recoil,will have to pull the 4 screws holding it on and and pull recoil off
you might get lucky as you loosen the bolts it might retract, if it does it is dirty inside and possible nylon guides wore causing it to bind. otherwise spring prob broke inside
Posted on Apr 06, 2011
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
I have a stihl fs 80, the starter cord will not retract after the first pull. The spring is still intacted but doesn't spring back when re-attached to weed eater.
One of 2 things come 2 mind, if the spring is still in tact it could be that the retract line might be slightly to long and forces the spring to over travel and lock up against itself. A simple test would be to pull the pull start to only 80%. If at 80% it retracts normally then shorten the pull string by a few centimeters . alternatively the spring may be over tensioned by a turn or two. to release pull the string out with the pull starter off the machine to about halfway, hold down the recoil to release the tension off the string and pull the string out towards you through the slot provided on the face of the recoil into a loop. Gently let the recoil slip one full turn at a time until there is just enough tension to pull the handle all the way back. if its too loose just revers the process one turn at a time. its not complicated, to do but can be tricky,
if DIY is not your thing, refer to someone better qualified,
Sep 05, 2012 | Garden
I cannot remove string holder from my Echo weed eater. I push down, turn it to the left, but it will not release.
hi jhhorn, don't push down while turning. just turn it till you hear a click then pull it straight out
Jul 18, 2011 | Echo Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
Pull cord will not retract
Have to take all 3 plastic covers (housings) off to get to the spring and tie the new pull rope or change the spring. Just did mine, spring just unlatched and string wouldn't retract. Did not have to by any new parts....works great! Took me 1 hour to get it done.
Sep 10, 2009 | Homelite 'Yard Broom' Leaf Blower
Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Garden Logo
373 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
