Question about Garden
LUBE OIL SPRAYING FROM THE AIR CLEANER AREA. - Garden
  • hughes3191 Apr 06, 2011
    We did find gas in the pan; the lube oil is colorless . It appears we have a gasket problem. II have asked for a manual for theRT190, but no results on that score.Thanks for your help.
    President:
  • 2,080 Answers
There are a number of possible causes for this symptom:
Too much oil in the crank case. If the oil level is over the recommended amount then oil from the crankcase can be forced up the vent tube into the air cleaner. Check the oil level and drain some off if necessary.
Also check that there is no gasoline mixed in with the oil which could be a sign of a leaky needle valve or stuck float in the carburator. Clean and service the carburator and then drain and change the crankcase oil if this is the case.
Or, it is possible the machine was just tipped on it's side and oil leaked from the crankcase up the vent into the air cleaner assembly. Sometimes just running the machine for a while with the air cleaner removed will clear up this problem. Then just clean up the excess oil and replace the air filter if one is fitted, and double check to make sure the vent line is not clogged up. Then just remember to keep the machine level at all times even when not running.
If it's not something simple like the causes listed above, then it may be a sign of a leaky head gasket or worn rings or something like that instead, which would mean more significant mechanical service is required.
Good luck.
Posted on Apr 04, 2011
Generator Won't start
Gap the plug at .030 What is most likely the main problem is whatever gas sat in the carb. Even with fresh gas there will be some old gas still in the float bowl. You may be able to drain the bowl and be OK but I have a feeling that the carb will need to come off and be disassembled and cleaned properly. You can try spraying carb cleaner (I dislike starting fluid as it is too volatile and carb cleaner does just as well in this instance) into the carb/intake. Remove the air filter, open the choke, and spray the carb cleaner in through that way if possible. You can actually keep an engine running by spraying with short bursts. Even by just spraying once you should be able to get the engine to start. If it does start but then will not stay running without spraying more into the engine then it is a carb problem.
Aug 24, 2012 | Coleman Powermate 6250 10hp Generator
Over spray or fish eyes
Over spray is just that getting paint on a surface you are not painting (protect adjacent surfaces) "fish eyes" are almost always some type of oil wax or something that was not cleaned off and the paint film moves away from it- always clean all surfaces first before any painting.
Perry
May 27, 2012 | Air Tools & Compressors
Driver door on 1992 accord will not open from inside or outside
It has either rusted so the latch doen't move or you have a loose screw/bolt inside the door. It will be a $150 job if you take it to a shop (non-dealer) and about $225 if you take it to a dealer.
You can try spraying some oil in the door latch area (where the door latches to the door frame) and let it soak for a day (spray a couple of times). Use an oil that is not too thick. You can even use WD40. If it does let loose with WD40, oil it again the next day with something that is really an oil (WD40 is just an electrical contact cleaner and not intended as a long-term lubricant).
Also, you can try to take the door panel off. There are some videos on youtube.com that will walk you through the process. You may not find an accord specificallly but a civic or camry instruction will be close enough to get the idea. Then you will have better access to lube it or see if a screw came loose.
Good luck
May 28, 2011 | 1992 Honda Accord
Senco sn901xo is leaking air out the top on the nailer.
This is a sign that internal components are sticking. Try spraying a light weight oil like wd 40 down the air inlet and dry firing the gun several times. If that does not work, pop off the top of the gun, that is your exhaust port. Clean the area with contact cleaner, and lube with air tool oil.
Mar 03, 2011 | Senco SN901XP Clipped Head Framing Nailer
Will this lock stand up to the humid salty air in the carribean?
The only way I would trust it is by spraying it weekly with a water displacing electronic safe cleaner and lube. Thank you.
Feb 26, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
Engine continually has high idle, wont kick down. also the choke light comes on when not pressing on the gas and makes an anoying sound. but only when not pressing the gas. what could this be? other than...
try getting a can of carb cleaner . removing breather and spraying gunk out of the inside of carb to free moving parts that are sticking. and also try spraying the outside moving parts of carb with penetrating oil
Jan 09, 2010 | 1986 Pontiac 6000
STARTS AND RUNS FINE BUT WHEN I START WASHING IT QUITS SPRAYING AND THEN BUILDS PRESSURE AND KILLS ENGINE
The reason it stops spraying might be a clogged gun, hose or nozzle-tip.
The reason for pressure buildup killing the engine might be a stuck unloader valve in the pump.
While you are checking each component of the "output" side, spray some penetrating lube into the "input" side of the pump (where the garden hose connects) and let it be working on the unloader valve.
Fix the spraying problem first:
Start at the nozzle and verify that it is open by using low-pressure air. Clean or replace as needed. Next check the hose (with nozzle and gun unhooked) and finally the gun/trigger mechanism.
All must be clear and open to perform correctly.
Next, pour a few ounces of power steering fluid (or similarly LIGHT oil) into the garden hose, attach it to the pump and turn on the water supply.
Leave the "output" hose, gun, etc. UNHOOKED and point the output port of the pump (where the high-pressure hose connects) towards a vacant, safe area.
Startup the engine and allow the oil in the garden hose to work its way thru. (About 1 -3 minutes of run-time.) Shut it down and attach the high-pressure hose.
Hope this solves the problem!
Oct 05, 2009 | Honda Pressure Washer PSI 3000
When the mower is started it runs very smoothly. The blow by from engine comes through the valve on side through floor of Carburator housing fouling air cleaner. when air cleaner off oil is sprayed on...
REPLACE THE CRANKCASE BREATHER ON THE SIDE OF THE BLOCK. IT IS A SMALL RECTANGULAR SHAPED BOX AT THE END OF THE HOSE THAT IS ATTACHED TO THE AIR CLEANER HOUSING WHERE THE OIL IS SPRAYING IN
Sep 29, 2009 | Garden
Tune-up
the phrase tune up is sort of a holdover from a different time, like lube oil and filter. still need to change oil and filter every so often, but as far as the lube goes most newer cars and trucks have sealed bearings that you can't squirt grease into, that was the lube part of lof. what you can do for a tune up on your truck, unless you are having a specific problem, is replace the spark plugs, change the air cleaner and pcv valve, maybe give it a dose of injector cleaner.you can't replace the ignition wires on a coilless ignition system without replacing the coil packs and it's not worth it unless you are having a problem. you should clean the battery terminals every so often and check all the fluids, make sure that your tires are properly inflated, stuff like that. the tires are one area where you can save yourself some money, you will get closer to whatever the rating is for the tire life (50,000 or 75,000 or whatever it was when you bought the tires) and you will save fuel and improve handling all the while.
Jun 01, 2009 | 2004 Dodge Ram 1500
Maintenance Plan
Lube and r/r cv boots, pressure drain tranny and engine at jiffy lube, check for smoke and or oil leaks. Replace plugs and wires (on 4 cyl do yourself and air cleaner), cabin air cleaner (IF ANY) Keep the oli clean and provide me with any check engine codes or service engine soon codes and I can get the answers for you to diazgnose any emissions or electronic errors.
Jul 16, 2008 | 2004 Toyota Camry
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
