Question about Dryers
MY PERFORMA DRYER IS APART TO CHANGE OUT IDLER PULLEY AND I AM HAVING A PROBLEM PUTTING IT BACK TOGETHER. DO YOU KNOW WHERE I CAN GET SCHEMATICS OR PHOTOS OF THE INSIDE?
My perfomma dryer make loud noise when it turning sound like bad brake how can i get that plm
Posted on Dec 17, 2008
How to replace belt on modle #rel4434awd dryer
Unplug machine. Remove lint filter. Remove the 2 phillips head screws under filter. Raise top by pressing in on clips with putty knife or flat screwdriver. Clips are just underneath top in front about 3-4 inches from each corner. Lean top back against wall. Unplug wires from door switch. Remove the two 5/16 inch screws holding front to cabinet. These are located in front about 3-4 inches down from top. One on each side. Lean front forward and lift up. Set front aside. Now look underneath drum and you will see belt. It goes around idler pulley and motor pulley. Study how it is on closely as you will want to install new one the same way. Flex idler pulley towards motor. This will loosen belt so it can be removed. Put everything back together in reverse order. It is easier to take apart than to put back together, so study steps you take appropriately. Hope this helps.
Oct 12, 2017 | Dryers
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
Drum stopped spinning. I took apart and took out the broken belt. Not positive if thats the only problem. I found a one inch in diameter plastic piece that seems to be broken, also. Not sure how to put it...
The plastic piece maybe the pulley on the end of the motor. Check the motor for a drive pulley it will have grooves in it for the belt. Since you are in there check the idler pulley for ware, the drum support pulleys in the back for ware, and see if you have any glide pads for the front of the drum. When you put it together put the belt around the drum before you put it in. Before you secure the front of the drum put the idler pulley on the belt. As long as you do not end up with extra screws you got it back together right.
Jun 01, 2011 | Dryers
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
I have a Maytag performa dryer and the idler pulley came off and i need to know where to attach the spring that it has back to.
Make sure the idler arm with pulley is in the right location and then hook the spring into the idler arm bracket, then look for where the spring might have been attached on the frame of the machine within the limits of a stretched spring.
I will also send you a website that may help you, they have schematics of dryers and it may give you some help.
http://www.partselect.com/ if not then try this one.
http://www.appliancepartspros.com/index.aspx
Good luck,
I hope this helps
Oct 13, 2009 | Maytag Dryers
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Idler pulley came loose and I need schematic so I can put it tog
the idler pulley fell out of its slot or it broke into pieces
if it just fell out of the slot you should take out the drum and just kind of play with it  depending on the dryer if you gave me your model i can take a look  and i dont know what kind of idler pulley you have so i am not much help AT ALL without it i;m sorry
Jun 08, 2009 | Kenmore 62622 Electric Dryer
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Elec. dryer
remove the front panel,find the idler arm wheel,the belt goes under the idler wheel and onto the motor pulley,put back together-mike
May 27, 2008 | Kenmore 65924 Electric Dryer
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
