Question about 2wire Wireless-G 802.11g ADSL Gateway
Used to use a modem.
I used to use a AT&T modem and everything worked fine. But now I am using my cousin's used At&t router and I connect it and all the lights are staying green except the wireless, but I can't even use the internet browser, just says "Page taking too long to respond."
You need to update the PPPoE login info to reflect your account info.
It's a great piece of hardware if you know how to use it.
Posted on Oct 21, 2008
**** the 2 wire it sucks my balls
Posted on Sep 14, 2008
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
My wireless laptop worked fine until i returned from vacation. Now i can't sign onto the internet. It says isp or no newtwork. What happened when I used this on vacation under my cousins router?
Check under network connections and see which network is set to default You may be trying to sign on and connect to the wrong network.
Please rate my help++++ Thanks for using FIXYA
Nov 24, 2009 | Microsoft MN-700 Wireless Router
Router problems
Make sure you have the cable plugged to the right spot. Your modem to the Internet/WAN port and your computer to port 1, the 2nd pc to port 2. Try to reset the router. There's a reset button at the back of the router. Hold it down for 30 seconds. Then do a power cycle. Unplug the power from the back of the router and also unplug the power from the modem. Wait for 30 seconds. After that, Plug the power back to the modem first, wait for all the lights to be steady then plug the power back to the router. That should do it.
Apr 01, 2009 | Buffalo Technology WHR-G54S Wireless...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
I have two computers that I want to share my cable internet connection. When connected directly to the modem the first computer conects to teh internet fine. But when I connect the computer to my Belkin...
Perhaps one of your ethernet cables is bad?
When everything is connected, the "WAN" light on your router should go on, as well as the lights for whatever network connections your are using for your computer.
Obviously the cable that you used to connect your computer directly to the modem is working, so try replacing the other one.
Sep 05, 2008 | Belkin Computers & Internet
No connectivity to internet
Looks like when you reset the router/mdm you have los all yur configuration and back to the default factory settings.
Bridge the modem first .
1. In your web browser browse to »<your mdoms deault gateway> This address will be found in your manual of your modem
2,Depending on your modem make sure you use "Bridged Mode (PPPoE is not used)"
3. Click Save Changes.
4. Then connect the router
5.Configure the router for PPPoE using your ISP uid/pass
6.Configure your wireless using WEP(if applicable)
7.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 26, 2008 | D-Link GamerLounge DGL-4300 Router...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Cannot receive IP from cable modem
I had this problem with another type of router. If the software is fine and the modem shows no problems, its probably your ethernet port on the router. Alot of routers ports go bad after a certain amount of use. It could have been a defect from start and just started to show problems. Logically at this point its hardware. You troubleshot the rest. Last thing to point at is the WAN port on the router going bad.
Jul 19, 2007 | D-Link GamerLounge DGL-4300 Router...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
393 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
