LCD projector is truncating left side of image
  • 10 more comments
  • Henry Winsor Apr 04, 2011
    Sony VPL-HS51 LCD Projector. I cannot find the interface cable for my camera, so I have no way of sending you an image that I know of.
    When I project the opening Warner Brothers logo onto the screen from a DVD (I picked Ben Hur), the left side of the logo is five inches from the left side of the projected image, while the right side of the logo is about 22 inches from the right side of the projected image. The overall image width is about 66 inches, and while the logo is not perfectly symmetrical, it's like the left side is losing about 15 inches.
    Another sign is when my Oppo Bluray is on the default screen, it says "pen" in the upper left corner when it should say "Open". There are some issues with both the horizontal and vertical adjustments in the projector; they do not function unless I lift the front of the lens up, then the rack and pinions engage and move the image on the screen.
    You misunderstand. I have no way of downloading a picture taken with my camera or with my phone to a computer so that I could upload it to the site. Photography is f minimal interest to me, I've never bothered to set up the technology so I can do anything with the photographs I have taken. It's on my list to do as soon as I have time, but the vacation photos are from last May.
    I have just checked the h and v shift on my projector and they are at 0, as is my vertical keystone.
    Then this is on hold until I have time to track down the necessary items and get you a picture.
    Why will it be open forever anyway?
    I've uploaded 3 pictures. The first is actually the last, loaded in reverse order. Note the truncated text on the bottom one, and the very off-center message and logo on the first two. I do not know whether the FBI message is useful, I think they show up somewhere but are not necessarily centered.
    That is shadow. The projector is back against the wall, I cannot shoot from behind it. The problem is on the left side of the image, not the right.
    I have already tried changing the horizontal shift and vertical shift on the projector menu, it does not change the situation. The only thing that has mattered is changing the picture using the external controls and they are adjusted to the extreme left at present.
  • Henry Winsor Apr 08, 2011
    Sorry, I haven't had much time this week. When I adjust the picture using the external controls, all I do is move the complete image as it appears on screen, I do not expose any more of the image. The picture is not being cut off by the external controls of the projector.
  • Henry Winsor Apr 12, 2011
    This issue seems to have dropped from my previous expert's attention. I think everything you might need is here, as he asked me to do everything possible except check to see if the power cord is plugged in.
    Dear Drew,
    My projector is not connected to a laptop; I currently have the cable box coming in via the component input while I have a bluray player using the HDMI input. My projector supposedly supports 720p, although it seems fixed at 1080i and I have never been able to find any way to change that setting. Frankly, 1080i is a pretty darn good picture, even if all of it doesn't appear on the screen. The problem is evident with both sources, so I'm pretty sure the problem is the projector
    In any event, I will go back tonight and see whether the vertical and horizontal positioning will affect the picture. The only other adjustment I have without going into the service menu (which I have no idea how to do) is a vertical keystone and I have set up the projector in a position that no keystone adjustment should be required. The last time I tried moving the h pos and v pos I noticed no affect on the screen, but maybe that is indicative of not moving them enough or that maybe they are too far to the left to make visible any movement or even that there is some problem in their workings.
    In the past week, I have recalled more of the history of the problem. I did not have any problem with the projector originally (I purchased it at least 6 years ago), but this problem seems to have come after changing the bulb first time, which was about 4 years ago (which should tell you how much TV I watch). It is more of a nuisance than a problem, but I do miss being able to watch poker and see both of the players' hole cards. If the h pos doesn't do anything, I may go ahead and reinstall the bulb and see whether there is anything in the install that is causing the problem.
    Let us worry about rating when we are done, as right now I don't think you'd like my rating. Do you have access to the instructions for accessing the service menu for a Sony VPL-HS50 if it becomes necessary? I may not be able to get back to you until Thursday.
    Dear Drew,
    You are being incredibly helpful. I will take advantage of what you have provided, but in order of increasing complexity. If my problem stems from a h pos value pinned too far to the left, well, I'm an even bigger idiot than even I think sometimes.
    Will let you know what happens, most likely by Thursday.
    Thanks again,
    Henry
  • 325 Answers
There should be settings in the projector itself for the top and bottom half of the image. They are settings to widen or shorten the width of the image from both the bottom and top.
Also, you can try to lower the resolution of the display setting of the laptop
let say 800x600 or 1027x768 and hope it helps!
Thank you and please rate! :)
Posted on Apr 12, 2011
  • 2 more comments
  • Andrew P.
    Andrew P. Apr 12, 2011
    Try this:
    Under the user menu (click MENU key on remote), check that Setup/Status is
    turned ON. If not, turn it ON.
    Exit the user menu by clicking the MENU key.
    To enter the Service Menu, on the remote quickly click ENTER, ENTER, UP,
    DOWN, ENTER. When prompted to enter SERVICE MODE click UP for Yes. To return to
    User mode click the same sequence then when prompted to return to USER MODE
    click UP for Yes.
    To enter the Factory Menu, on the remote quickly click ENTER, ENTER, LEFT,
    ENTER. When prompted to enter the FACTORY MODE click UP for Yes. To return to
    click UP for Yes.
  • Andrew P.
    Here is the manual also:
    http://www.mediafire.com/?xbglcgll0yxyrh...
    It is in PDF format and will need to be viewed accordingly.
  • Andrew P.
    Hopefully it is that simple.
    Best of luck,
    D. Palmer
  • Andrew P.
    Also, I'd like to add. I've seen bulbs installed slightly crooked that have caused this kind of behavior. Another option, considering the length of time the bulb was installed, it is possible to have been dropped or bummped in 4 years. This would also point to the possibility of a crooked bulb in the bulb housing.
    Thank you, best of luck again.
  • 4,889 Answers
Can you please tell me whats the make and model of the unit? Also can you take a picture of the screen and post it here so that I can see for myself what it looks like?
Posted on Apr 04, 2011
  • 4 more comments
  • eagle338
    eagle338 Apr 04, 2011
    Sounds like H-position, V-position issue. You do not need to connect your camera to it Just take a picture of the screen with your camera and attach it to your comment so that I can confirm thats the issue and suggest the adjustment procedure
  • eagle338
    I can wait for the photo. I have to see it to determine what the problem could be depending on how much of image is truncated. Sounds like focus block issue but we should be absolutely sure before changing the service menu settings thats why. May be you can purchase the cable on e-bay or something
  • eagle338
    Yes thats right. It will be open forever anyway.
  • eagle338
    I also see black smudge on the lower right corner. Is that a shadow or is it part of the problem?
  • eagle338
    Ok did you try changing the aspect ratio settings? Also increase the right shift value so that the picture will move a bit to the right.
  • eagle338
    By external controls you mean the buttons on the projecotr? If so then try shifting the image to the right. The picture is cutting off on the left hand side because it was pushed to extreme left
Polarview 211e
Go to:
System Preferences (you can get there by clicking on the Apple Menu in the top left corner) -> Displays -> Detect displays
After you click "Detect Displays" your G3 should automatically send the display image to your projector.
Feb 27, 2008 | Polaroid Polaview 211E Multimedia...
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
No signal
are you sending the signal to the projector. FN+CRT/LCD button key simultaneously. if you do this 3x you will get the following. no image at projector image at laptop scree, image at projector and laptop screen, image at projector no image at laptop scree,
Jun 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Uncentered image using projector
reset the settings to factory default. is it cut off evenly, or is it uneven and shadowed? if it is the latter and you have a dlp projector, you have a collapsed light tunnel. if it is cut off evenly, go into the settings and make sure the resolution and screen size matches.
Jan 27, 2010 | Sony Office Equipment & Supplies
Infocus X2 has discolor on the left side of image- what could this be.
the light tunnel is collapsing and will need to be replaced. you could either get the part from an infocus service center or send it to them to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 06, 2010 | InFocus LP290 1100 Lumen XGA LCD Projector...
Laptop screen image is truncated on data projector display (Dell)
Had the same problem, tried a Factory Reset from the menu and it seems to have worked. Don't know what caused in in the first place
Nov 11, 2009 | Dell Office Equipment & Supplies
How to make image right-side up when hanging the projector from the ceiling in an inverted position.
instalation properly ,surface of celing not in level ,left side scerew little unscerw problem solved.put some washer&check
Jul 05, 2009 | Epson EMP-S4 LCD Projector
Problem with truncated image from data projector
You will need to setup the displays from the computer running the projector.
Setup the projector as being a second monitor pretty much and make the adjustments from that in display properties on your computer, or your video card may have it's own control panel for this as well.
Hope it helps =)
Apr 08, 2008 | Computers & Internet
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
