Monitor was in standby mode, computer was on. Now it shows no signal and when we try using the menu button (2) it flashes white, black, red, green, blue then a teal color.
    President:
  • 1,623 Answers
The monitor is not receiving a signal from the computer which is why the multi coloured bars are showing. Ensure the lead is connected and is connected to the correct port of your computer. If it is connected correctly then either your graphics card is faulty or the lead, or monitor is
Posted on Apr 03, 2011
  • Computers & ... Master
  • 5,660 Answers
1) "The monitor is not receiving a signal from the computer"
You know your monitor is good. The test color patterns also indicate this.
The next thing to check would be the monitor cable, IF detachable. Use a Known to be good monitor cable for a test.
If not then another Known to be working monitor, and cable would then be used for a test unit.
After the above diagnoses is taken then it's time to check the graphics card, (Video card. Same/same), IF there is a separate graphics card.
If not the computer uses Integrated Graphics.
The graphics is OnBoard.
(Graphics chip soldered directly to the motherboard)
A graphics card would then be used to diagnose.
However at this point I would like to point out, that most computer failure can be attributed to a bad Power Supply, and/or the computer is dirty inside.
LED lights may light, and fans may spin, but the Processor isn't receiving enough power to turn on.
Bad Power Supply.Weak voltage power rail.
No Processor operating, No video signal from the computer.
1) If ALL of the LED lights were on at once they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
This is why even though LED lights may light, and fans may spin making it appear the computer is working, in reality it isn't.
Do you have another Known to be good, Compatible power supply for a test unit?
Perhaps one in a computer that is no longer used.
For questions regarding any of the above, please post in a Comment.
Regards,
joecoolvette
Posted on Apr 04, 2011
Dclcd monitor
Seems the screen resolution of your pc is high (higher than your monitor can support). You may lower the resoltion by connecting your pc to another monitor temporarily and changing settings then.
Nov 18, 2013 | Philips Computers & Internet
Hp monitor flashes solid colors
Hi there, the mode the unit is in is like self test. Try first to disconnect vga cable from pc and see if the there is notification "no signal" poping -up to see if the problem is not graphics. Anyway you can try to disconnect power cord from monitor and wait a while then try again power it on. If all this doesnt help it will be more then good advice to RMA it if still in warranty. Tnx
Sep 23, 2013 | Samsung Computers & Internet
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
My screen will not come on and it flashes this message once "VGA NO SIGNAL". Then power button turns from green to yellow (standby mode). HELP!
What computer is it?
When you say power button is yellow, do you mean on monitor or on computer?
Can you try a different monitor?
Perhaps try a different video card
Aug 29, 2010 | Computers & Internet
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Screen flashing differnet colours
My Benq lcd monitor does the same thing.
Sep 17, 2007 | Videoseven R17PS 17" LCD Monitor
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
