Machine is blowing fuses and tripping the breaker. Fuse has been replaced. No wires in the main control panel appear to be damaged. I have not smelled any burning. Help.
  • 31 Answers
Possibly a bad cycle selector thats what was with mine
Posted on Apr 03, 2011
  • ksb1azure Apr 04, 2011
    Thank you - we are checking the lid switch and the motor. We will also check the cycle selector.
  • droidslip Apr 04, 2011
    your welcome
No lights, won't run. Nothing. Worked fine yesterday.
Hello. Critical question--is the dishwasher on that GFCI circuit!? If so, (A) you might have voided any warranty and (B) you should NEVER have appliances with digital boards on a GFCI circuit. Why? Because the method GFCI breakers and outlets use to keep us safe(how they reference current to ground) can blow out the electronic control boards plugged in to the circuit they monitor. I am ALWAYS telling my customers to immediately switch out an outlet or breaker which is protecting a washer, dishwasher, or microwave. I know that electrical codes often mandate that a GFCI device be within 3 feet of a water source but the design engineers didn't think about that one...It often is buried in the users manual to NOT connect the device to a GFCI.
Now, after all that, I need the model number of your unit to help you most accurately--some dishwashers have a main fuse on or near the main control board. If this fuse opens, voila! The unit is D-E-A-D until you replace the fuse. However, if there isn't a fuse, you've got a blown main board(and possibly user control panel, too). Power slams like the one you experienced are notorious for damaging control boards. That's why power outages are so destructive--they either blow out boards immediately or cause them to fail in about 3-4 weeks afterwards due to the damaged chips on the board starting to fail from over-current/voltage. I hope I helped you!
Oct 02, 2015 | KitchenAid Dishwashers
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
No power after self cleaning
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
My whirlpool dryer LEB6300l0 dose not heat up .....
Hello there
Please check the following items that i have listed below
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 16, 2011 | Whirlpool LEB6300 Electric Dryer
Start your wash machine
If your washer doesn't seem to work at all, check these: No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 01, 2010 | Maytag PAV2300 Top Load Washer
Is there a fuse or circuit breaker i can reset if 220v was put to my washing machine? i was rewiring the breaker panel and got two circuits reversed, the washing machine circuit and the water heater...
Jan 10, 2010 | Washing Machines
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Roper Dryers
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
My parents had a close lightning strike and now their washing machine (Maytag A9200) doesn't work. Is there an internal fuse or something? we are hoping this isn't a total loss.
First check the main circuit panel to verify that the breaker didn't trip. Sometimes with double pole breakers, you'll get half of it tripping (even with the tie bar that connects both halves).
Make sure you flip the breaker all the way OFF and then turn it back ON, that way, a partial trip will get reset. Just turning a breaker to ON after tripping, won't reset most breakers,
I would find it unusual for only the washer to have taken a hit so try the above and let me know if that resolves the issue, or if you have any other damage from the storm.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Washing Machines
Dryer problem
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
