How can i connect my RCA by Thomson digital broadband cable modem it is DCM425 to a belkin router to make a wifi connection?
  • 492 Answers
Plug the Ethernet cable into the yellow jack on the wireless router. Plug a wireless receiver (like Netgear or Belkin) into a USB port on the computer. The Belkin will come with instructions, software and a default password (on the bottom or the router). Install the CD drivers and follow the prompts.
Posted on Apr 03, 2011
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
How to setup a rca thomson digital broadband to a tm router
You have to reboot your modem anytime you connect a new device to it, this is what is great about routers! They act as the reference device to your modem since the modem can only "pair" with 1 mac address at a time, this allows you to connect and disconnect devices to your internet without having to reboot your modem and to also have multiple device use the same internet service at the same time.
Unplug the power to your modem and just follow the directions that came with your router on how to wire it to your modem and set it up. Once you are done plug your modem back into power and you should be up and running.
Jan 31, 2013 | Thomson Rca / Digital Broadband Modem...
I dont know how to connect a belkin wireless router to thr rca modern router?
You will need 2 ethernet cable to set it up Tha first one will go from the ethernet port in your cable modem to the ethernet port of the router mentionned Modem. The next cable will go fron one of the port of the router to the ethernet port of your Computer,
This second cable is placed temporarely to be able to do set the routers settings,
After this is done insert the Cd that came with your Belkin router and it should guide you through the different setting pages of the router.
Jul 25, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have the rca dcm425c modem wired to my mac in my office. I want to use google logitech tv in my other room with my big screen tv. I was told all I needed to add was a router that I would hook up to my...
USB is NOT RJ45 connectors. They are very differant as in water and bar of steel.
RCA DCM425 Digital Cable Modem eBay
Read backside cable connections. "ETHERNET" connect to router "Internet" connection. Plug ALL devices into "Ethernet" dump USB cable and store away. USB may shut down Ethernet connection while connected.
May 24, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computers & Internet Logo
352 people viewed this question
David Payne
David Payne
