Question about Mountain Td-one Bicycle Front Derailleur Bike Parts 149
Does not want to shift to first gear. - Mountain Td-one Bicycle Front Derailleur Bike Parts 149
    Guru:
  • 347 Answers
Check your cable tension, and your limit screw settings. If that doesn't fix the problem, take into your local bike shop, they will be able to diagnose and provide a solution.
Posted on Apr 04, 2011
Changing gears
Hi, Dave and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return spring weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r3-forums.com/forum/522-drivetrain/14065-shifting-issues-thread-problems-your-shifts.html
Gear shifting problem
OEM parts for Yamaha
Gears stuck up shifting
My Motorcycle can shift up or down anymore Is the problem bent shift lever
Mar 09, 2014 | Yamaha Motorcycles
How difficult is it to change the shifter cable
Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
5
Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
6
Test the functionality of the shifting cable by moving the gear shift in and out of gear.
Jan 03, 2013 | Saturn Cars & Trucks
Toyota Tercel stuck in gear
Its a gear shift issue.
The shifter needs to be inspected. The shifter assembly is got misaligned, it has to be open and realign.
There are many other possibilities. But if it was working right up till now and suddenly this occurred then its shifter assembly alignment issue.
Also i suggest you to refer these gear shift issues, which are mostly noticed. These are direct links with appropriate solutions to the specific problems of gear ****.
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Nov 28, 2012 | 1993 Toyota Tercel
56 ducato van wont go into 1st 2nd gear easy
GEAR SHIFT ISSUES
Thanks.
Nov 28, 2012 | Cars & Trucks
My scond & fourth gear is grating
GEAR SHIFT ISSUES
Thanks.
Nov 27, 2012 | Cars & Trucks
Shifting when driving
The shifter needs to be inspected.If the gears are shifted automatically.The shifter assembly is got misaligned,it has to be open and realign.
There are many other possibilities.But if it was working right up till now and suddenly this auto shifting occurred then its shifter assembly realign issue.
Also i suggest you to refer these gear shift issues,which are mostly noticed.These are direct links with appropriate solutions to the specific problems of gear ****.
Click the link below:------
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html --------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html ---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html --------- Car will not move when in gear? http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ---------- Chrysler PT Cruiser only goes in First gear?
------- 2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html -------- 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html -------- Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html --------- Car will not come out of Park?
----------- Automatic transmission will not go into high gear?
-------- Buick Park Avenue: Transmission will Not shift into drive?
------------ No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html ------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html --------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html -------- Car Transmission will not go into Park mode?
---------- 1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html ------ Shift indicator directly goes to 2nd when key is turned ON?
-------- Third gear missing and engine losing power?
-------- Chevrolet silverado has whining sound in gear?
---------- 2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html ---------- Hard to shift gears on Manual transmission?
-------- Car hard shift at slow speeds?
--------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html --------- Automatic transmission shift lever hard to move on cold mornings?
------------ 2000 Nissan maxima shifts hard?
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
==========These details will help.Thanks.
Nov 24, 2012 | 1995 Mercury Mystique
Renault trafic 100 dci gear selector
There are few related help links related to gear shift issues:----
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html Car will not come out of Park?
No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html Shift indicator directly goes to 2nd when key is turned ON?
2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html Hard to shift gears on Manual transmission?
Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html Automatic transmission shift lever hard to move on cold mornings?
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
My 1993 Gmc Sierra 2500 automatic first gear shifts hard also from park to drive others gears are smooth i have overdrive
The gear shift lever indicators tell you what gear you have an automatic transmission in on your vehicle. The shift solenoid tells the transmission when to shift gears and what gear to shift into. Newer model automatic transmissions have electronic shift solenoids that are activated and change gears based on the speed the vehicle is traveling. Troubleshooting either one of these transmission components is relatively easy if you know a little about automobile mechanics. With the right tools, you can determine whether the transmission shift solenoid is having a problem. Gear shift indicator problems can be determined simply by moving the gears into their designated position.
Transmission Shift Solenoid
  • 1 Raise each corner of the vehicle up with the car jack and place jack stands under the frame. Make sure the car is raised high enough so you can work under the car freely.
  • 2 Slide the drain pan under the transmission fluid drain plug. Remove the drain plug with a ratchet and socket, and let all the fluid drain out of the transmission. Remove the transmission pan bolts with a ratchet and socket. Pull the pan away from the bottom of the transmission, revealing the transmission shift solenoid.
  • 3 Wipe off the shift solenoid with a shop towel. Disconnect one of the two plugs that attaches to the shift solenoid. Turn the knob on the volt meter to the ohms setting, so resistance can be measured. Set the volt meter on 200.
  • 4 Take the black lead of the volt meter and touch the negative battery terminal wire. Take the red lead of volt meter and slide the tip into the terminal plug you just disconnected from the shift solenoid. Look at the reading you get on the digital display of your volt meter. Determine if the reading is between 12 and 25. Readings below 12 or above 25 tell you that the shift solenoid is not working. Reattach the plug to the shift solenoid and pull the second plug attached to the solenoid. Perform the same procedures on this plug wire. Replace the transmission shift solenoid after determining it is bad.
Gear Shift Indicator
  • 1 Move the gear shift into the desired gear. Look at the gear labels and the arrow, or other indicator, to see if the gear shift indicator lines up with the selected gear.
  • 2 Move the gear lever to another gear and look to see if the indicator lines up with the selected gear. Misalignment of the arrow will tell you if there is a problem. Moving the gear shift to "neutral" but having the indicator show the transmission is in "drive" tells you the gear shift indicator is not working properly.
  • 3 Try each gear position to determine how much misalignment is in the indicator. Slide under the car and check for a loose gear shift cable. Check all the gear shift cable connections to ensure they are all tight and are not missing. Tighten any loose gear shift cable clamps or bolts. Replace the gear shift cable if you find that this is causing the misalignment with the gear shift indicator.
Feb 02, 2012 | 1993 GMC Sierra
How to install a transmission shift cable in a 2000 Cavalier
    • 1 Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
    • 2 Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
    • 3 Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
    • 4 Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
    • 5 Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
    • 6 Test the functionality of the shifting cable by moving the gear shift in and out of gear.
Sep 23, 2011 | Chevrolet Cavalier Cars & Trucks
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Mountain Td-one  Bicycle Front Derailleur Bike Parts 149 Logo
76 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
