Question about HEWLETT-PACKARD Pavilion DV 6 Laptop
My Msn messenger does not respond and forces close on a Windows 7 64 bit, it hasnt worked in a couple months.
    Sergeant:
    Champion:
  • 230 Answers
Hello, Your PC hardware specs are pretty good. What you can try to do is to uninstall MSN messenger from the Control Panel and download and reinstall it. That should fix the problem.
Cheers!
Posted on Apr 03, 2011
  • Andrew P.
    Andrew P. Apr 11, 2011
    Better yet. Run in compatibility mode. Right click MSN, then properties, then compatibility mode tab, then xp sp3. Click apply, and then click ok...
    DONE...working with xp sp3 drivers for 32-bit appications.
    Hope this helped
Platfom isn't working on msn??
=? try this
close MSN
than go to
start
control panel
add&remove programs
‘windows live essentials’(if using WLM 2009)
‘windows live messenger’(if using WLM 8.5)
click on 'remove'
and then on 'repair'
wait til the wizard finishes
sign in again
=?if it does not work uninstall from the control panel
Start
control panel
add&remove programs
'windows essentials' ( if using WLM 2009)
'windows live messenger(if you use a previous version)
remove
=?if it doesn't work
? You have to use this program created by microsoft to remove WLM 9.0 beta3/WLM 2009
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e…
once started search in the programs list for "(All Users) Windows Live Messenger [14.0.5027.0908]"
mark it with a mouse click, then click on the 'remove' button'
=?Windows live Messenger 2009
http://download.live.com/?sku=messenger
?windows live messenger 8.5
http://www.microsoft.com/downloads/detai…
?PLUS live 4.80
http://www.msgpluslive.net/download/
(don't support the sponsor)
?NOTE: if you are trying to install WLM 8.5 and having problems, using Windows Installer CleanUp Utility search and remove "(all User) Windows Live Beta (all programs) [14.0.5025.904]"
=?if it doesn't work use "zapmessenger"
A regular issue faced is the dreaded “Another version of the product is already installed”, “Your computer has a newer version of MSN Messenger than the one you are trying to install”, ““Your computer has a newer version of Windows Live Messenger than the one you are trying to install”, “The feature you are trying to use is on a network resource that is unavailable” and similar messages.
http://messengergeek.spaces.live.com/blo…
http://www.softpedia.com/progDownload/Za…
Hope I helped MSN expert Dr Reed
Sep 24, 2009 | Microsoft Windows Live Messanger
My windows live messanger signs in for at least 6 seconds before it closes completely ... theres no error or anything it just closes before i can chat with anyone or anything its really annyoin ive...
=? try this
close MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Aug 15, 2009 | Microsoft Windows Live Messanger
Msn key ports will not fix!
Dear Friend,
First of all, always check the status of your web browser before signing in to windows hotmail messenger.That means that if you try to sing in, be sure that work offline mode in your browser is not checked.Secondly, have you run the MSN MESSENGER port configuration?Third and most important, have you opened the ports in your firewall?
Here is the list of thee ports that MSN Messenger uses:
1366 MSN Messenger
1367 MSN Messenger
1838 : TCP MSN Messenger (Gamevoice)
1863 : TCP/UDP MSN Messenger primary (incoming)
5190 : UDP MSN Messenger (incoming)
6891 : TCP MSN Messenger Filetransfer (incoming) - ports 6891 - 6900, one port per file transfer
6901 : TCP/UDP MSN Messenger Voice Telephony (incoming)
5004 : UDP MSN Messenger, ports 5004-65535. Used for AUDIO and VIDEO. Caution: securty risc! Do not open ALL these ports!
5004 : UDP MSN messenger (dynamically uses a port in this range 5004 – 65535 - requires uPNP in your NAT router and/or firewall). Used for AUDIO and VIDEO. See Microsoft website for details....
Good Luck!
Jun 22, 2009 | U.S. Robotics (USR8200USR8800KIT)
My webcam won't work on msn
download the new windows mesenger here http://messenger.live.com/ this would be easyist to fix the problem. or 1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Jun 11, 2009 | Sony Computers & Internet
Norton 360 keeps disconnecting MSN
I uninstalled the Norton 360 program. Windows Live Messenger seems to be able to stay online now.
Apr 02, 2009 | Microsoft Windows Live Messanger
Microsoft lifecam vx 3000 freezing
Try the cam with another messenger. MSN sometimes has bandwidth issues and cams freeze up.
Mar 06, 2009 | Microsoft LifeCam VX-3000 Web Camera
MSN Live is not Responding, I sign in to MSN Messenger Live and it doesn't respond. What can I do to fix this problem with MSN Messenger Live?
HEY guys!!
i had da same problem i went to google and i didnt find any way so i start finding it my way ..IF msn is not responding after 3 seconds when you signin...And if you did system restore dat what had happened to me ... i ve the answer... Go to Control panel> firewall>exception> .... IF YOU VE MORE DAN TWO WINDOWS LIVE MESSENGER CHECKED..here is da mistake ...just uncheck one and signin and see..IF its again not workin check the other one.. CAUTION: leave da msn (phone) NO NEED ........I HOPE MY ANSWER IS HELP FULL
Nov 10, 2008 | Microsoft Windows Live Messanger
Messenger Error 80072745
This is sometimes caused by the cache left on Internet Explorer. If your internet's working fine, then follow these steps.
Close MSN Messenger
Open Internet Explorer. Set it to work offline (File > Work Offline)
Close Internet Explorer and reopen it. Now set it to work online (File > Work Offline).
Open Command Prompt (Start > Run > type "cmd" and hit enter)
Type "ipconfig /flushdns". You should recieve a message that your DNS has been successfully flushed.
You should now be able to connect to MSN Messenger. Open MSN and see if the problem is fixed.
Oct 19, 2008 | Microsoft Windows Live Messanger
Help
If you have MSN Messenger follow below:
Windows XP
Windows Messenger is a native Instant Messenger application to Windows XP. This application can be used to set the output device of your choice. In turn, this information will carry over to the MSN Messenger 7.5 application settings.
Launch Windows Messenger and execute the audio tuning wizard.
  1. Go to “Start”.
    Select “Run”.
    Type “msmsgs” and click “OK”.
  2. In theWindows Messenger, click “Tools” and select “Audio Tuning Wizard”.
  3. Follow the steps which are provided by the “Audio Tuning Wizard” and select your desired Microphone & Speaker device.
  4. Once this process is complete, close the Windows Messenger application.
    The configuration change made through Windows Messenger should now be set in the MSN Messenger 7.5 application.
Mar 06, 2008 | Logitech QuickCam Express Web Camera
HEWLETT-PACKARD Pavilion DV 6 Laptop Logo
155 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
