SONY WIDE SCREEN PROJECTION TV. MODEL # KP-51WS520 5 BLINKS ON START-UP , PICTURE MOVING HORIZONTALLY , WAS TOLD COULD BE " A " OR " B " BOARD.............
  • 12 more comments
  • solafou Apr 04, 2011
    CAN I REPLACE THESE BOARDS MYSELF ? I AM HANDY WITH TOOLS, HAVE DONE OTHER ELECTRONICS REPAIRS, REPLACING DIODES, ETC. WHERE CAN I GET PARTS ??
    I HAVE VOLTMETER AND AMPERE METER TESTING EQUIPMENT..................I HAVE HAD UNPLUGGED FOR 2 WEEKS.....................IT IS NEXT TO IMPOSSIBLE TO GET TECH'S OUT HERE ! TELL ME HOW TO ACCESS THE PART #'S YOU ARE REFERRING TO AND I WILL OBTAIN THEM FOR ORDERING .
    I HAVE BACK OFF TV , WHERE IS THE # LOCATED ON CARD ??
    THE NUBERS I GET ON BOARD DIRECTLY BENEATH TUBE ARE
    A 1125142 AND A 1054146A THESE NUMBERS ARE ON EACH OF THE 3 BOARDS BENEATH THE TUBES
    ON THE SIDE OF THE TUBES 3 BOARDS
    A 145088 A
    OR 140566 A ( CANNOT READ THE NUMBERS TOO WELL )
    All the cards have the same #'s on them......so how do I purchase them and replace them ?
    those are the cards attached to the bottom of the tubes that have the # A1054146A on them
    I am sorry , my bad , the numbers end in 46 A , 47 A , 48 A
    the prefix is the same A10541......
    IT IS AX-1X
    No chance to test, what about replacement as a precautionary measure anyway ?
    No evidence of scorched boards or brown solder joints..........all is clean and dry
    A-1054-151-A
    Is this the part # I need ? I have copy of Sony repair Manual I downloaded last year concerning another problem , so a little direction from you on where to obtain parts and a quick refresher on the installation of them would be helpful
    MAHALO EAGLE, I HOPE THIS DOES THE TRICK.....I AM NOT AFRAID OF DOING MORE " SURGERY " IF NECESSARY
    ALOHA
  • 4,889 Answers
It is not the B-board the 5 blinks error code on this model means there is a problem with the video out ICs on the CRT boards. It is unlikely to be related to A or B boards. The problem lies within CR/CG/CB boards wich are attached to the back of red, green and blue CRTs located at the back of the set.
Posted on Apr 04, 2011
  • 10 more comments
  • eagle338
    eagle338 Apr 04, 2011
    You can obtain the parts from partstore.com. I can find you the boards if you can get me the part number printed on them. As for whether you can replace them yourself, that's a tough question as this is a high-voltage circuit(30,000V) and I think its best left to a tech considering the fact that the CRTs act like giant capacitors and store voltages of this magnitude in them for several days-weeks after being turned off and unplugged.
  • eagle338
    Ok. Then its safe to work on. First up you will need to remove the back cover and the CRTs look like tubes. Behind each CRT is a tiny board and those are the onesin context. It is pretty straightforward and shouldn't be too hard.
  • eagle338
    Its usually has 10 characters startingwith A like A-xxx-xxx-xxx
  • eagle338
    Please stop using capitol letters. The A1054146A part number is the correct one. The other two part numbers should be 10 characters long as well
  • eagle338
    All 3 have same numbers? Thats weird coz the IC numbers are different too. Let me look up the service manual and get back to you
  • eagle338
    Hi, can you please confirm the chassis number AX-1X? It will be on a label at the back of the tv.
  • eagle338
    I was just looking at the service manual and it mentions that IC452(CRT drive IC) can also be faulty. Unfortuantely this IC can only be tested with an oscilloscope as we have to measure the voltage pulse. Any chance you have one/can borrow one from a friend so that we can confirm the location of the problem before ordering the boards?
  • eagle338
    Well we can do that but I did not want to go by trial and error. Since you alread have the set open check on the 3 CRT boards near IC9101, IC9201, IC9301 for any signs of brown marks near the solder joints. That should help us figure out if the CRT boards are bad or not so that we can be sure its the A-board
  • eagle338
    Ok then please get me the part number off the A-board. If you have trouble locating it let me know and I will give you the service manual that has a listing of all parts including their location.
  • eagle338
  • eagle338
    Yes that is the part. The service manual only lists the first version of the part which are improved upo in later versions. So you should always go by the part number of the board in the tv. As for the disassembly read the section titled "A Board, D Board, and G Board Removal". You just need to remove the A-board, so read only upto that. The replacement is pretty straight forward. Just unplug the connectors from the older board and plug them into the replacement. Be wary of static electricity. Be sure to touch a grounded metal object for a few seconds before touching the board. Repeat this from time to time when you are not in contact with the boards. Wear a pair of cotton/rubber tennis shoes for added protection against any residual voltages that are still in the set.
  • eagle338
    Thank you for using Fixya! I am positive that it will do the trick.
HI, I was wondering if there is way to adjust the horizontal position on the screen of Sony KP-57WV600. By adjusting I mean a way to shrink the displayed picture horizontally or vertically.To give you an...
There is button "Wide Mode" on tv remote, press it repeatedly to select desired zoom mode to view best fit picture in screen.
Click Sony Support link to download user manual free copy and check page-48 for details.
Thanks.
Jan 06, 2011 | Sony Televison & Video
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Oct 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
