Question about Maytag MMV1153B Microwave Oven
Does the Maytag Microwave mmv1153aab - have a fuse for the light under micro? Light wont work, new bulb, wires seem intact....?
RepairClinic
  • 32 Answers
SOURCE: Kenmore over range microwave oven / no power at all
Unfortunately, there is a good chance that when the bulb shorted out, it damaged the control board. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. The relays for the fan and the lights are part of the board. The power should always be disconnected when these bulbs are replaced or the board will be damaged. We would have an appliance repair person take a look to see what the deal is with the microwave.
Go here for Kenmore Microwave Parts: http://www.repairclinic.com/Kenmore-Microwave-Parts
www.RepairClinic.com
Posted on Feb 05, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: micro doesn't cook,vent or light, but timer works. Estate TMH14XM
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 11, 2009
  • 574 Answers
SOURCE: exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Posted on Mar 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Recently replaced under microwave bulb while light
Yes it is a fuse issue. Inside the microwave chassis if you follow the power cord to the fuse block there will either be a 15 A or 20A fuse.
The fuse is Item 47 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227571&diagram_id=22974429#d22974429
close up:
http://www.appliancepartspros.com/part_details.aspx?part_id=2631556
BEFORE you replace the fuse, check the light bulb socket contacts. Most likely when you changed the bulb the side contact was somehow forced onto to bottom contact. Correct that problem first, other wise the fuse will probably blow again.
You can obtain the fuse at most any Appliance Parts source or Hardware outlet.
I have to ask... Does the microwave work but the fan motor does not? If that is the case you could have damaged the relay on the control board.
Your feedback would be appreciated.
Thanks for using FixYa,
Kelly
Posted on Apr 26, 2010
heatman101
  • 43501 Answers
SOURCE: Problem with the Microwave Ovens
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 24, 2010
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
Lights not working
follow this steps and fix it God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gPpzp9iL
Sep 30, 2013 | Amana Microwave Ovens
The lights wont come on
test this and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2aavxew74
Jul 30, 2013 | Microwave Ovens
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
Light will not work even with new bulbs. Fan
one of your micro swichts are bad.
Dec 21, 2009 | Microwave Ovens
The under unit light burned out and tripped the circuit breaker. Replaced bulb and reset breaker but light doesn't work. I see there is an internal fuse. Could this be the problem as there is no power...
These remarks are not make and model specific.
Did you test the new light bulb?
I would not normally expect a burned out light to trip a breaker.
You may have a blown fuse. I suspect the fuse you see is to protect the oven. If you popped a breaker, you may have blown a fuse. I'd be looking for a short somewhere, maybe in the wire that powers the light, maybe in the hardwire that supplies the oven.
Make sure you turn the power off before you go poking around. And, above all, avoid the silver can inside, it IS lethal.
Let me know if this helps.
A
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
My microwave quit working
You have obviously damaged the circuitry. Service is expensive. Unless the unit is under warrantry my advice is to replace the oven. The newer ovens are very reasonable and have great features. Check Home Depot.
Ray
Dec 31, 2008 | Maytag Microwave Ovens
Maytag MMV1153B Microwave Oven Logo
102 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
