Good Day I have a problem with my LG V872NWK DVD/VIDEO Combo. It is stuck on Progressive Scan. I pressed every button on my remote but nothing happens. When I press the SETUP-button on the remote, the screen on my TV-set stays blue. Please help me because I can't watch any DVD. Thank you very much. Ruben
BElectric
  • 1140 Answers
SOURCE: i cannot get the progressive
Hi -
The instructions for switching progressive scan off have been posted on FixYa numerous times, but I'll save you searching for them and post them again . . .
1. Remove any disc from the unit and close the disc tray.
2. Wait for the DISC message to appear on the display
3. Hold the STOP button on the front of the player for at least 5 seconds then release.
PSCAN should disappear from the display on the front of the player and the video output should return to the standard interlace setting
If you are still unable to switch PSCAN off, please post back for further assistance.
Regards,
BElectric
Posted on Apr 24, 2011
SOURCE: Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Posted on May 20, 2007
SOURCE: Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Posted on Oct 05, 2007
SOURCE: Vizio L37
you probably changed the input mode.
Posted on Nov 10, 2007
  • 17 Answers
SOURCE: Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Posted on Feb 04, 2008
No power
If problem is on the remote, first press the DVD/VCR button if there is also one for TV.
Nov 05, 2013 | Sony SLV-D300P Progressive-Scan DVD-VCR...
It says progressive scan on the screen
You can try this (it may or may not work for this model; it does for the Zenith XVB342 and XVB442 combos):
On the main unit, not the remote, and with no discs in the DVD tray, press and hold [ STOP ] button for 5 - 10 seconds, then release. Progressive scan should now be switched OFF (the display indicator for progressive scan should disappear) and normal video output should be restored.
Hopefully it works (there are no available manuals online for this model).
May 22, 2011 | Zenith ZDX-313 DVD Player / VCR Combo
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
How to stop Progressive Scan Mode?
Yes, I found the users manual.
To fix it: Press and hold the STOP button (on the remote) for more than 5 seconds.
It worked!
Feb 05, 2008 | GoVideo Go Video DVD/VCR Combo
I need to know how to get the progressive scan feature turned off so I can view DVD's.
Thanks for the progressive scan advice. I have a Go-Video DV1130 Combo I didnt have a DVD in the combo and I pressed and held the stop button on the combo instead of the remote and it came out of the progressive scan mode so maybe it works both ways? But anyway Thanks for the advice it sure helped me.
Dec 31, 2007 | GoVideo DV1130 DVD Player/VCR
Progressive scan button is stuck
What progressive scan "button?" On the unit? Remote? In the LCD display? I don't see one....
Nov 19, 2007 | Sylvania DVR90VE DVD Recorder/VCR
Per manual, with DVD selected and stopped, press and hold p/scan button on remote for 5 seconds to switch between pscan and interlace mode.
Nov 10, 2007 | GoVideo Go Video DVD/VCR Combo
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
