Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
I refilled the black ink cartridge, and when I put it back in the printer, the printer says ERROR 13 meaning the ink level cannot be detected. Its essentially a brand new cartridge. What do I do? Ive tried shaking the cartridge, I put it in and out several times and nothing seems to make it work
  • 11 Answers
Go to inkjet411.com for many solutions. Also, you can take your cartrdige to Costco and have them refilled and reset on many newer Canon Cartridges. www.costcoinkjetrefill.com
Posted on Jan 08, 2015
    Problem Solver:
  • 12 Answers
It is not possible to refill the original Canon cartridges. The ink level indicator is integrated in the chip on the cartridge. When refilling, the information on the chip will not be changed and keeps giving the info that the cartridge is empty.
Posted on Apr 11, 2011
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
I changed theblack ink cartridge twice and it still won't print in black, colours are printing but no black
Ink level data is stored in a chip of the cartridge. Once the cartridge is empty, ink low message will appear eventhough you refill the cartridge. You need to deactivate ink level detection function to continue printing in case of usage of refill ink .
Search google on how to change ink level detection
Chris Thrash
B52Computers
Jan 10, 2011 | Epson Office Equipment & Supplies
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
What is the meaning of E 4?
An E4 error usually means your printer did not detect your ink cartridges. To fix the error, press and hold the Black & Color button for 5-10 secs. If you are using refilled cartridges, remove the cartrigdes, switch printer off and then back on. Then reinstall the cartridges and press copy.
Aug 31, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Check ink u163 error message
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Jun 21, 2009 | Canon MX300 Office All-In-One Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Nov 27, 2008 | Canon Office Equipment & Supplies
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
205 people viewed this question
old marine
old marine
