Question about Canon FAX-JX200
How to rectify problem "check"6000
  • eastmark Apr 05, 2011
    it doesn't work
    Guru:
  • 767 Answers
The problem is that you may be not lifting up the top cover (where you put the paper in). As a result it locks the carriage and creates this error. Lift up the cove at the top of the machine, then turn the machine off and on again and your problem will be solved.
You can also try:
Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while (maybe an hour or so), plug the power cord of the machine back in and turn ON the machine. If this does not work, turn off the machine, unplug it from the power (wall/ac pluggin, if hooked into a computer/phone line, its fine), and hold down the power button of the machine for a minute straight. Then allow it to sit unplugged for a while, and try again.
For this machine, check 6000 isnt a normal occurance. Its not an actual error to be fixed by yourself. Just make sure you don't have a paper jam, new ink, printer head is clean (the printer head is the thing between the ink, and the paper, usually a microchip covered with a clear, plastic coating underneath where the ink sits).
Posted on Apr 05, 2011
    Sergeant:
    Champion:
  • 209 Answers
Try turning off the fax and turning it back on to reset it. If the power button doesn't work, then unplug it for 10 seconds and then plug it back in. If that doesn't work, let me know.
Posted on Apr 03, 2011
Fax machine shows no dialing tone. what must I do to rectify?
check phone line is connected to fax machine
check phone line works with a phone plugged into the phone line you are using
Oct 19, 2016 | Office Equipment & Supplies
My printer canon mx328 error 6000
This information is directly from the Canon website, basically it suggests something is stuck inside. Other articles I found mentioned one person found a paperclip stopping the works.
---- quoting Canon ----
6000/P03 - Orange and green light blinking 3 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
----- end quote ---
Best wishes -
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/maxify/error_codes/#6000
PIXMA Printer Error Codes and Error Messages
Jul 05, 2015 | Canon Office Equipment & Supplies
Manual for canon fax jx200 Problem Not faxing or copying Green light blinking? showing"!! 6000!!" which is number code of problem
This is a link to Canon for your Fax JX200 Users Guide.
http://gdlp01.c-wss.com/gds/0900007827/FAX-JX200_JX201_Users_Guide_EN_US.pdf
CHECK 6000 code:
LineFeed signal is not detected.
The paper feed in the printer is not detected, the motor may be defective, or the transparent plastic disc on the motor, respectively, the corresponding sensor.
Nov 20, 2009 | Canon FAX-JX200
How can I change the location ID of tis fax Machine?
Press
71
set...keep pressing set until you get to OWN ID
clear
key in fax number
set
stop
Nov 06, 2009 | Panasonic PANAFAX UF-6000 Fax
My question was how to change the date and time on a panasonic uf-6000?
Press
Function
71
set
key in date and military time
set
stop
Jun 10, 2009 | Panasonic PANAFAX UF-6000 Fax
Panasonic fax machine Panafax UF6000
Press
Function
74
set
12
set
2 for always 3 for incomplete only
set
stop
C6000 error code in km1635 copier
Hello sir; here is the way to reset;
enter "10871087", then enter "163" press "start" the "CLE" will display press "start" to reset, press "stop/clear" to exit.
May 09, 2009 | Kyocera Office Equipment & Supplies
Changing date and time for panafax uf6000
press function-7-1-start- change the time and date on the machine. then hit start then stop
Jan 12, 2009 | Panasonic PANAFAX UF-6000 Fax
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
How to enter TSDI on a panafax machine
Function
71
set
key in phone number
set
stop
stop
Nov 19, 2007 | Panasonic PANAFAX UF-6000 Fax
Canon FAX-JX200 Logo
48 people viewed this question
old marine
old marine
