Question about Kenneth Cole Automatic Leather Strap KC1607 Watch for Men
Doesnt keep accurate time. Once time has been set and watch worn for several hrs, time is incorrect
This watch will not keep working. I spin it around and it works for a min. or two.... is there a way to manually wind this watch?
An automatic watch can be wound up by holding them level and swinging it from side to side and several minutes (one maker said swing it 200-300 times).
Once fully wound, the watch should keep working if it is worn daily. Most automatic watches will run for 2-3 days if not worn.
Dec 20, 2010 | Lucien Piccard Automatic Diamond New...
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
If the watch is not worn for a day, is it normal for it to stop or slow down? Vintage SS mens datejust, oyster perpetual.
mcdevito75 here, Yes it is normal, especially if your Rolex is an automatic watch. The motion of your Wrist / Hand keeps your watch wound thru the Counter balance on the movement, as the counter balance turns it winds the mainspring little by little, thus keeping your watch wound. Once you take off your watch, if long enough the mainspring simply un-winds and slows and will eventually stop your watch completely. You can keep your Rolex wound even when you take it off by means of a watch winder, a small machine that will keep your watch in motion, or by hand, by rocking the watch back and firth in your hand for about 30 seconds, say before you gpo to bed at night, this way there is always some wind to your watch.
Aug 15, 2010 | Rolex Datejust SS
I have 2 sector watches. BOTH lose time when I'm visiting the UK but keep accurate time when I'm in the U.S. Both have new batteries. It's really bizarre. Any ideas what the problem might be?
I have looked at their web site and cannot identify your watch from the number given, as they do not give numbers to their models.
The only thing that may change between countries is the transmission frequency of the radio timing pulses. (This assumes that your watch is an "atomic accuracy" type, which registers local transmitters.)
If this is not the case, then your watch is in the same class as those that work accurately when being worn but not when they are taken off (or vice versa). A mystery all round!
Feb 07, 2010 | Sector 450 2653450035 Wrist Watch
Date on my watch
It sounds like your still off by 12 hrs. You can usually set the date between 12 am and 11:59 am on most watches, but the best thing to do in this case is to set the date right after midnight, to be sure.
Feb 24, 2009 | Citizen Eco-Drive Calibre 5700 AT1070-54L...
My date just will not set, it clicks two times but doesn't move
it's time for a overhaul and cleaning...the stem may be worn out. Rolexs need this service about every 10 years.
Jan 18, 2009 | Rolex Day-Date President 118238 Wristwatch
Fossil watch doesnt keep the date accurate
Going to have to exchange it again. Somthing internally is incorrect with the watch.
Jan 14, 2009 | Fossil Black Dial BQ9328 Watch for Men
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Swatch Skin #SFK254 ,Time always late
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
Aug 04, 2008 | Swatch Skin SFK254 Watch
Kenneth Cole Automatic Leather Strap KC1607 Watch for Men Logo
48 people viewed this question
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
