Question about Technics RS-TR272 Single Cassette Deck
Can not record from internet to cassette tape or see any volume on audio window
    Brigadier General:
  • 8,546 Answers
Wouldn't that be a function/malfunction of your PC? Review the sound controls and connections in the PC.
Posted on Apr 03, 2011
The sound is very faint even with the volume turned all the way up.
When you open the cassette door, there is a metal piece in the back that pushes the tape ajainst the head. If that is broken or bent, you can get low audio. Other possibilities are a dirty tape head or misaligned head.
Aug 01, 2011 | Panasonic RR-930 Desktop Cassette...
Tip
Is there a program out there that will convert my old cassette tapes or vinyl...
The short answer is yes. There is a program out there that will record cassette tapes or vinyl records to CD. Today, I will show you how. If you have the right software and the right cords, getting your cassettes and Vinyl onto your computer, then onto CDs, is a pretty easy task. Just follow the steps below and you will be on your way to bringing your audio into the 21st century! What you need: To make the conversion, you will need a (free) audio recording program, a tape or record player and a cord to connect the device to your computer. Here's a breakdown:
1. Audacity. This is the program that will record your audio to your computer.
2. LAME-encoder. This is a file that will convert your audio to MP3.
3. A record player or cassette player. Hopefully you already have one of these.
4. A cord to connect the player to your computer.
The first step is to install Audacity and LAME,
Now that we have the software installed, we can look at connecting your tape player, or record player, to your computer.
Your player will have one of two types of outputs. You will either have a standard 3.5mm headphone jack, or RCA audio output jacks.
If your device has RCA outputs (left image)to connect to your computer.
If your device has a 3.5mm jack (right image) to connect to your computer.
The other end of the cable will connect to the line in jack on your computer
Now that we have the software installed and the cassette/record player connected to the computer, let's record something!
Put a cassette or LP into your player. Get the player to the place where you want to start recording and pause or stop the player.
Now, let's stop messing with all this hardware and get the computer set up. First, go to your control panel and open your audio settings.
In XP, go to the audio tab and click "volume" under sound recording. Place a check next to "line in". If you don't see a "line in" option go to options and click advanced. Place a check next to "line in" there.
In Vista/7 go to the recording tab. find your line in, select it then choose "set default". Click on "properties", go to the levels tab and turn up the level to 80 or 100. (This varies depending on what you are recording so you may need to adjust this to get it right).
As you can see, Audacity is pretty much a more advanced sound recorder. To begin recording, press the play button on your record/cassette player then click the red "record" circle on audacity. You are now recording to your computer! When you are done, click stop on audacity and press stop on your player.
After recording, you can now export your audio as an MP3. Go to the file menu and click "Export as MP3". You can now choose the name of the file and save to wherever you want. You are done recording!
on Dec 14, 2009 | Computers & Internet
Can not record to tapes from internet. Audio volumn window does not indicate any sound. Dont know where to start to look for problem. It worked well until it developed the problem. ...
Go to device manager open audio video controlers ,if you see a strange symol beside your device i.e example-yellow question mark for X-P.This means your computer is missing a driver.Please send comment.
Apr 03, 2011 | Technics RS-TR272 Single Cassette Deck
How do I record my cassettes into my PC
find a tape player/recorder than has the capability to connect to a computer connect your tape player/recorder to your computer open windows explorer navigate to the tape player open it then select the files you want to copy to your computer right click select copy then navigate to the place where you want them saved or you can select the files hold the muse cursor on them drag them to the place you want to save them and drop them into it
hope this helps
Nov 28, 2010 | Behringer (UCA202) Sound Card
I have used this machine on stage for 20 years and love it!! however i just bought a new one to have for backup, and can't seem to make it dump!! i hook up a pin jack to a recorder just like i always...
There has been a tend to use MIDI sysex files for dumps rather than the unreliable audio recording... The cassette method can be tricky. Setting volume levels for record and playback is tricky.
Also using cassette recorders of newer design often have "compression" that automatically adjusts the volume level on record... these do not work very well... IF you have changed recorders since you had positive results, this might be the problem.
An additional thing can be the recording media as there are differebt coatings for tapes and bias levels.
Save yourself grief and use a MIDI adapter for your PC and record MIDI sysex dumps for these units instead oof cassette audio.
Aug 17, 2010 | Alesis Sr 16 Stereo Drum Machine
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
Copy audio tapes to CD's
Hello Trevor,
Easiest way I can think of is as follows:
1. Connect the "phones" of your cassette player to the "Line in" of your PC. Line In is coloured blue, you will need a a 3.5" to 3.5" male audio cable.
2. Next, install some sound capturing program on your computer. I can recommend Audacity: http://audacity.sourceforge.net/
3. Start the cassette player, check the volume levels, do some short test records. Once you are satisfied with the result, rewind and record side A of the cassette, then side B. Using again Audacity, you can cut the desired parts of the record and save them in the format and quality you like, I guess *.mp3.
4. Burn the files to a CD. You can use CD Burner XP Pro: http://cdburnerxp.se/
I hope that I have been very helpful. :)
Nov 13, 2009 | Audio Players & Recorders
I cannot erase a tape
Audio cassette tapes are not erasable.
You must record over the recorded portion or side of the tape you want to delete. You can of course record silence if you want a "clean" or "new" tape (turn the volume all the way down and then press the record button).
I found that I could do very fast with some recorders by pressing the record button and simultaneously pressing fast forward.
Oct 25, 2009 | Olympus Pearlcorder S701 Handheld Cassette...
Audio tape cassettes,old pre-recorded and home recorded play too slowly and drag. All brands. Tape deck plays new tapes fine.
A good cleaning to the rollers and tape head with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | ION Audio TAPE2PC Single Cassette Deck
Copying Audio Cassette to CD
Generally speaking yes. You could take the audio outputs from the tape deck and plug them into the audio inputs for any line in the DVD recorder. Then press record. Finalize it once your done.
A more professional way to do it is to record them back into a computer. If you have Windows Plus! Digital Media Edition installed into your computer, there is an analog recorder installed. All you have to do is plug the audio output of the tape deck into the microphone jack of your computer. Then it will convert them to mp3 format. That way you can use Windows Media Player to burn the CD with by creating a playlist. If you have Windows XP and you need Plus! it should be available at any computer store for around $20.00. Wome versions of Vista may have this feature included into the operating system as well.
Feb 17, 2009 | TruTech TT1620 DVD Recorder
Technics RS-TR272 Single Cassette Deck Logo
53 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
