Question about Crystal Graphics PowerPlugs Transitions I Full Version for PC
I download the instalation of power plugs transitions and when i run it, it says Failed because isnt compatible with 64 bit versions i dont know what to do, i have a windows 7, 64 bit, 8gb of ram, 1 tb of HDD
I cant install it on windows 7
Try downloading the Vista driver. Make sure that you select the 32- or 64-bit version, as needed, from http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_Z605&focusedTab=DOWNLOADS#4 . Click on filter to get the correct file. To check the version of Windows that you have, click Start > Control Panel > System and Security > System. If you see x64 after the OS version name, get the 64-bit driver. Otherwise you need the 32-bit driver.
Make sure to disconnect the data cable between the computer and the printer, if you have connected it. Uninstall any problem driver (generic from the Windows OS or a failed Lexmark driver install) before installing the new driver.
If you still have problems, uninstall the driver again. Then use the compatibility mode. Right click on the exe file that you downloaded from Lexmark and choose Properties. Under the Compatibility tab, check the box for "Run this program in the compatibility mode" and select Vista. Then right click again and choose "Run as Administrator".
I hope this helps.
Aug 11, 2011 | Lexmark JetPrinter Z605 Color InkJet...
I got an error message on the initial installation. There was an indication that platforms were not compatible...something about x64 or x86? and no download
Double check if the version you are installing is compatible with you computer. You will need to know if you are running a 64 bit or 32 bit system. If you have a 64 bit system then you will need the 64 bit software.
Aug 01, 2011 | Singer Computers & Internet
I have a new computer and when trying to install my PowerPlugs CDs, it tells me that it is incompatible with 64-bit windows system. How can I resolve this?
you cant. you will have to get crystal graphics that is compatible with 64 bit system . the software you have now probably will only run on a 32 bit operating system
May 05, 2011 | Crystal Graphics PowerPlugs Transitions I...
I'm using Windows 7 64 bit & I can't Install "Bitware plus 4.0" in my computer. I see this message after starting Install: Title is: Unsupported 16-bit Application Message is: " The...
any 16 nit or 32 bit is not compatable with 64-bit operating system but yes they do make a 64 bit version of that software make sure your downloading the right version
Apr 01, 2011 | Computer Associates BitWare Plus 4.0 Full...
I had a 32-bit webtricity 2 and other programs that are 32-bit, I have a computer with Windows 7 64-bit and having trouble installing these programs because during compatible with the 64-bit OS is there...
64 bit OS can run 32 bit software but if the software provider has a version for 64 bit it might require you to download this version ad prevent you from installing the 32 bit version.
Kind regards
Mar 06, 2011 | Computers & Internet
I can't get Calendar Creator 12.1 to run on my windows 7 64-bit system
Windows 7 Compatibility for Broderbund Calendar Creator version 12 :
32-bit(compatible) and 64-bit(We are working with the software publisher to confirm this product's compatibility) -->click HERE! to navigate .
Run the program in compatibility mode:
1.Right click on the program's shortcut, .exe file, or installation program;
2.Click on Properties.
3. Click on the Compatibility tab. (see screenshot below)
NOTE: If the Compatiblity options are grayed out, then it is a 64 bit program and cannot be changed.
OR..
You can use windows xp mode to run calendar creator .
Please navigate to this page click HERE! and follow microsoft instructions ..
Please let me know if you need any further assistance.
Dec 29, 2010 | Broderbund Calendar Creator 12 for PC
I have windows vista and when i try to run itunes i get this message. 'the version of this file is not compatible with the version of windows you're running. Check you're computer's system information to...
Hi, you can check which version of Windows you have by clicking on the Start button (the Vista orb) and from the Start menu, right click on Computer. Choose Properties from the menu that appears, and you'll see a lot of information about your computer. There should be a line that says whether you have a 32-bit version of Vista or a 64-bit version. Depending on which version you have, you'll need to download the compatible version of iTunes. You can download both versions here:
http://www.apple.com/itunes/download/
For the 32-bit version, click the Download Now button; for the 64-bit version, scroll down to where you see the link for 64-bit installer on the left hand side and click it.
Hope that helps!
Nov 20, 2010 | Dell Inspiron 1525 Laptop
IE8 installation failed, and said that The installation does not support your system architecture (32/64-bit) I'm running on Windows 7. What seems to be the problem?
If you downloaded the 32 bit edition and you are running a 64 bit machine you need the 64 bit application, if you have a 32 bit machine and downloaded the 64 bit veriosn you need the 32 bit version.
Oct 07, 2010 | Microsoft Internet Explorer 8
Hi, my c4480 printer is not compatible with my windows 7 (64bit) therefore i tried installing one of the drivers from hp. When i pressed on the installed driver an error box appears saying : The version of...
Heres the trick to it. You download the version you need 32 bit or 64 bit save the download.
next locate your download right click it choose properties click on the compatibility tab.
there is a choice to run it in compatibility mode check the box and select your operating system.
next you need to check the option to run as an administrator witch is at the bottom of the
compatability tab apply these options and hit ok.
finaly you will right click it and choose run as administrator wait for the installer to start and follow the promts. and you can use your printer. If your printer is hosted off another computer make sure the workgroup is the same so that windows 7 can find your printer. Search and add the printer your done get more information and help from here
Aug 26, 2010 | HP Photosmart C4480 All-In-One InkJet...
Can not install video controller & modem on windows XP 64 bit
This Computer is not compatible with 64 bit operating system and all drivers will not work with 64-bit version. Do not wait for any answers, just reinstall 32-bit XP. However, the drivers you have already installed, do not work as a 64-bit, they work as a 32-bit.
Apr 27, 2009 | Toshiba Satellite A135-S2386 Notebook...
Crystal Graphics PowerPlugs Transitions I Full Version for PC Logo
155 people viewed this question
Top Crystal Graphics Computers & Internet Experts
David Payne
David Payne
Are you a Crystal Graphics Computer and Internet Expert? Answer questions, earn points and help others
