Question about Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
The red light on my magic chef deep freezer came on and it stopped working all together?
SOURCE: I need parts and a diagram for a magic chef
Wrong Model Number
Posted on Sep 10, 2009
SOURCE: I have a magic chef freezer MCCF5WBX the power
Had the same problem for the same unit. In my case, the theromostat was sticking. Mine was still under warranty so I called Magic Chef, who in turn gave me to a local repair person. In order to save him time to travel out for a diagnosis, he asked me to tap on the control to see if the run light comes on. Sure enough the run light came on and cooled the freezer. Try tapping on the unit control to see if it kicks on. My email address is mearlj@aol.com. I'd like to know if it works.
Posted on Sep 25, 2009
  • 3 Answers
SOURCE: I have a magic chef freezer that is not keeping
i have a magic chef freezer that is not getting cold
Posted on Apr 18, 2010
  • 389 Answers
SOURCE: Magic Chef MCCF5W do not works. fast freeze is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 2468 Answers
SOURCE: magic chef portable freezer not cooling.
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
Posted on Dec 26, 2010
Magic chef freezer model HMCF7W2 stopped working. Red power light on, freen lught off!???
I think if it is full of food I would call for service instead of using a website that may be able to help or not.
May 05, 2017 | Magic Chef Freezers
Should green "compressor on" light always be on?
read the user manual
the light may only come on when the compressor is working
talk with a service agent for the unit and ask them
Dec 29, 2016 | Magic Chef Freezers
How to add 134a to magic chef deep freezer
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
Nov 08, 2015 | Magic Chef Chest Freezer MCCF5WBX
Red light is on all the time, wont stop running
Some freezers have a pilot light that is constantly on whenever power is being applied. If the compressor seem to run constantly, check for a bad lid seal. Also, the thermostat may at may be defective
Jul 19, 2013 | Magic Chef 5 cu. ft. / 142 liter Chest...
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
Jan 27, 2013 | Magic Chef Chest Freezer MCCF5WBX
Magic chef freezer temperature indicator light on, not usually on?
Is it a red light? If so it's not reaching temperature (the alarm is about -12c) If it's a yellow light, you've accidentally switched on "fast freeze". If it's a green light it's just the power supply light.
May 08, 2012 | Magic Chef 5 cu. ft. / 142 liter Chest...
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
What shoud I set my magic chef deep freezer at
It should be set between 10 and 20 degrees Fahrenheit
May 27, 2010 | Magic Chef Chest Freezer MCCF5WBX
I have a magic chef freezer MCCF5WBX the power light is on, but the run light is not on and it is not working
Aug 18, 2009 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW Logo
142 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
