My laptop can connect to the internet when the blue ethernet cable is connected directly to it but when I pull the cable and go straight to the linksys54G2, I cannot get internet. The "saturn" light on the router blinks all the time. Is the router shot?
    Sergeant:
    Champion:
  • 217 Answers
Have you tried to reset the router? Unplug the power cord to the router and wait 10 seconds, then plug it back in and wait for it to recycle.
Posted on Apr 03, 2011
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
My cable internet provider has provided me with an Ethernet cable which connects directly to my PC. My PC's MAC address is registered with the ISP. I use a PPPoE connection to access the internet with a...
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
Feb 04, 2011 | D-Link DIR-600 Router
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Getting low or no connectivity error when trying to connect laptop and other devices to 5-port DLINK switch. Lan line going to switch is confirmed working as i'm able to plug the laptop and other devices...
please change the cable which is connecting your laptop to D-Link DES 1005 Ethernet Switch.
This error appears when you have either a bad cable or bad switch or NIC card on Laptop.
As you have Laptop and other devices and getting the same error , so i suspect issue with the cable.
Please use a new Straight LAN cable.
Oct 31, 2010 | D-Link DES 1005 Ethernet Switch
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Laptop doesnt find connection to cable modem
download setup wizard to find connection from windows
Feb 12, 2009 | Acer Aspire One PC Notebook
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
