Question about John Deere Garden
,my problem is when i engage the mower the engines tries to shut off, the mower part does not turn
    Brigadier General:
  • 3,911 Answers
Luckily you have a mower which can always be serviced. Look up John Deere in the phone book. Call them and they can come get it and fix it for you.
Either you have a missing/broken/misalinged deck belt or a frozen bearing. A mechanical boyfriend can fix the first issue with enough time, beer, and a few basic tools but the bearing is going to require a more in depth treatment.
Posted on Apr 04, 2011
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
Engine runs, but when I engage the electric PTO why does it go dead?
Newer mowers have a safety interlock that prevents the mower running when going in reverse. My guess is that the reverse switch is on and when the PTO is activated the engine dies like you shut off the key.
Second idea is that the device the PTO drives is frozen up. Test this by trying to see if it turns with the engine off. When you engage the PTO the engine chokes down because it can't turn the PTO.
Mar 29, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
When running the mower, it shuts off immediately when trying to engage blades(pto)
Hi Digger:
I've two possibles come to mind for you to check.
1) Engine OFF - Make sure that all of the blades and pulleys can turn freely.
2) Engine OFF - Double check belt routing. Move engage lever ON/Off and look at what movement happens. It may be that the belt is on the wrong side af a mounting flange and binds when engaged.
Cheerfuls.
Sep 18, 2015 | Garden
I have a LT2000 21 HP lawn mower. The mower is brand new, just put gas in it today. I can't get the mower blades to engage without shutting the mower off. I have tried it in neutral, forward, sitting...
Hi, Have you tried to turn the blades by hand ( WITH THE MOTOR OFF ) I suspect there may be some transit packing that you may have missed. The blades should turn freely with the motor off and the blade engaged. There is a blade brake which stops the blades turning when the drive is disengaged which might need adjusting .
Hope this helps.
Dec 30, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a JD 160 mower that shuts off when you turn on the pto switch for the blades, I have checked the charge in the battery and it is good, it will start to turn the blade and then the engine dies, just...
Most likely cause is the seat safety switch is not functioning properly, ie. when sitting in it to allow blades to engage, if failed it will act like there is no one on the mower and the blades get engaged it will kill the engine, like having the ignition shut off.
I hope this is helpful to you.
Aug 10, 2011 | John Deere Garden
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Drive and blade engagement shutsdown the engine.
Sounds like the seat safety switch.
Mar 05, 2009 | Poulan Garden
Garden Logo
78 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
