Thank you for contacting
fixya.com.
You did not mention the
type and the brand of your washing machine. However given bellow are some
options you can try.
Whirlpool Duet Dryer -
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
In Hoover washing
machine try holding down the temperature and eco/rapid options together to turn
off child lock. Some series use "TEMP and OPTION" at the same time.
Please get back to us if you have further query else please accept the
suggestion.
The cleaning cycle is the only cycle that will run, I removed the top cover and pulled all the DC connections off the CCU and pressed start, power did not shut off. I plugged each one back in one at a time and pushed start after each connection was made. The power shut off after the DL (door lock) was plugged back in. I pulled the door lock assembly out, pulled it apart and checked the contacts and wires inside, everything looked and actuated correctly. I am not sure which direction to go next, as the door lock will function correctly in the cleaning cycle. I would guess their is a short somewhere in the front control panel, (I am not very good at guessing). I have heard their is a way to get the washing machine into a self diagnostics mode, I can't figure out on how to get my unit to do this. (model number is 110.47561603)
