Question about Eagle FISHEASY 245DS PORTABLE PTT-WSU DUCER (Eagle)
Have a fisheasy 245ds.Each time I turn on, it is in simulator mode. Change to normal mode and will not read depth nor show any display except voltage. have tried to reset but same problem. Have tried another transducer, still no help? Any suggestions?
5 Suggested Answers
saailer
  • 1871 Answers
SOURCE: Just purchased and Eagle Fishmark
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on Sep 11, 2011
SOURCE: Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Posted on Oct 27, 2009
SOURCE: When I turn on my Eagle Cuda 300, it goes straight
I have had two units that have done the same thing and I am on my third one under warranty - it must be a fault with their product
Posted on Mar 05, 2010
  • 1833 Answers
SOURCE: I have a Eagle cuda
First check the Battery status of your Fish finder, replace the battery. Check the transducer and suction-cap. Master reset after replacing of battery may need for your fish finder. It can solve your problem.
Posted on May 02, 2011
Tip
Watch glossary: D
DEPTH ALARM
An alarm on a divers' watch that sounds when the wearer exceeds a pre-set depth.
DEPTH METER or DEPTH SENSOR
A device on a divers' watch that determines the wearer's depth by measuring water pressure. It shows the depth either by analog hands and a scale on the watch face or through a digital display.
DECK WATCH
A large-sized ship's chronometer.
DEVIATION
A progressive natural change of a watch's rate with respect to objective time. In case of a watch's faster rate, the deviation is defined positive, in the opposite case negative.
DIAL
Face of a watch, on which time and further functions are displayed by markers, hands, discs or through windows. Normally it is made of a brass - sometimes silver or gold.
DIGITAL WATCH
Said of watches whose indications are displayed mostly inside an aperture or window on the dial.
DIVERS' WATCH
A watch that is water resistant to 200M. Has a unidirectional rotating bezel and a screw-on crown and back. Has a metal or rubber strap (not leather). May have a sapphire crystal and possibly, a wet-suit extension.
on Jan 11, 2010 | Watches
What does exp.sim mean?
In Live View mode, evaluative metering is always used to determine correct exposure, though exposure compensation is available. The Exposure Simulation function will attempt to recreate the exposure level that would be obtained with your current settings on the LCD display. This may raise noise levels of the live view feed beyond what could be expected in the final image, since it must operate with a fast enough shutter speed to achieve its required refresh rate. The aperture also remains open by default, and so the exposure simulation doesn't indicate the areas in focus unless you configure the Set button to provide depth-of-field preview, and then hold it down during live view. Exposure Simulation will attempt to continue even with depth of field preview active, though this may raise the live view noise levels even further. If you pass outside the range where the live view feed can simulate your exposure, the "Exp. Sim" icon near the bottom right of the LCD will blink, as a warning.
Nov 24, 2013 | Canon Cameras
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
Eagle Fisheasy No screen display and only beeps
You could have blown the transducer.....it is supposed to be in water before you turn it on. A 5 gal. bucket inside the boat would be fine for when out the water. Put the transducer in the 5gal bucket with water and try again. You may have to get another. sorry.
Dec 20, 2009 | Eagle Fisheasy 250ds Fishfinder
When I turn on my Eagle Cuda 300, it goes straight to silulator mode. When I turn off the simulator, it won't display the bottom and the depth reads way deeper that actual. I've tried changing settings,...
Try this, hard reset-FYI-This will delete saved data
1. Turn unit OFF-Press and hold the UP arrown key
2. Press power, unit will enter production keyboard test mode
3. Release the buttons
4. Press PWR/CLEAR key 7 times. (SYSTEM INFO SCREEN)
5. Press MENU/DOWN and unit will shut off
Hope this helps
Jul 12, 2009 | Eagle Cuda 242 Fishfinder
Mar 14, 2009 | Eagle Boating
How to set date and time on a sports cardinal watch
Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Oct 24, 2007 | Canon NP 6050 Copier
Eagle FISHEASY 245DS PORTABLE PTT-WSU DUCER (Eagle) Logo
83 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Phil Walker
Phil Walker
Are you an Eagle Boating Expert? Answer questions, earn points and help others
