Whatever componenets you have, satellite receiver, DVD Bluray, etc. should be hooked to tv for both audio and video, referrably by HDMI, then you can hook you digital optical out from tv to digital in on your Bose system. If you have component in to tv you can use that to but, you will ahve to provide audio tp tv through Ditgital in or composite cables(red, white, RCA)
SOURCE: I have a Bose Cinemate
If you're using a Cinemate for HDTV listening you're missing out on multichannel sound. However, since it only supports analog 2-channel audio AND a TV or monitor is NOT a meaningful contributor to the listening experience, maybe you could extract the TV audio from the cable box where it ultimately originates in the first place. I'm sure it has a convenient and compatible RCA pair.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
