Question about Asko W6863 Washer
Asko W6863. Water seems to leak from inside dispenser box and pools under left side of washer which stands on a plinth. This doesn't happen on shorter cycles. Any ideas on problem would be helpful.
Timon90
  • 126 Answers
SOURCE: Asko Washer leak
Remove the bacpanel, and locate the leak. Be careful for moving parts, and electricity.
It may leak from the pump or from a hose or so.
Posted on Jan 23, 2008
SOURCE: asko washer 20004
It could also be a leak in the hose that connects to the pump, toward the front.
Posted on Apr 04, 2008
  • 5 Answers
SOURCE: ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Posted on Aug 03, 2008
abhishek33
  • 1239 Answers
SOURCE: asko front washer is leaking
  1. how-to-repair-a-dishwasher-2.jpgDishwashers are usually protected from overfilling by a float switch. This switch is located in the bottom of the unit. Here's how to check and replace it:Step 1: Open the door and remove the bottom dish rack. Check to see if the float valve is stuck. If it is, clean away food debris around the float. With a screwdriver handle, lightly tap the top of the float to free it.Step 2: If tapping doesn't work, remove the lower access panel and locate the bottom portion of the float and float switch. Test the float switch with a VOM set to the RX1 scale. Unscrew one electrical lead wire to the switch terminal, and clip one probe of the VOM to each terminal. If the meter reads zero, the switch is not faulty. The trouble is probably in the timer. If the meter reads higher than zero, the switch is faulty.Step 3: Replace the switch with a new one made to fit the dishwasher. The switch is held to a mounting bracket with screws; remove the screws to get the old switch out.Step 4: Connect the new switch the same way the old one was connected
  2. thank u ;;;;rate it
Posted on Sep 11, 2008
  • 351 Answers
SOURCE: My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Posted on Jun 16, 2010
Testimonial: "You confirmed my suspicion Thanks "
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
How to fix water leaking under front of refrigerator
dose water gather inside the fridge, if so, it may be the drain in the inside back of the fridge is blocked, try cleaning it through with a long pipe cleaner,
or if it has a water dispenser on the front, try removing the plastic plinth at the bottom of the unit and checking the water connection,
Good luck
Nov 12, 2014 | Whirlpool Refrigerators
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
Location of fuses on w6863
likely cause is that the short that tripped the breaker has caused damage to the electronics. there may be a fuse on a PCB on this model, but I am not 100% on that. you should check for resistance across your pump and motor, and inspect for water leakage as this often causes components to fail in this way.
Nov 08, 2013 | Asko W6863 Washer
Setting control unit W6863
read your manual, if the control unit is faulty, you must replace.it
God bless you
Oct 11, 2012 | Asko W6863 Washer
Why does My washer have a moldy musty smell?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Apr 30, 2011 | Asko W6021 Front Load Washer
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
Leaking from base of machine
Probably got a sht gasket. Check under the washer to see where the water is comng from. This is a common problem.
Nov 15, 2008 | Asko W6441 Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Asko W6863 Washer Logo
43 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
