Question about Philips DVP3960
Sound issues? My television sound volume is set at 50- the highest it can go...and the sound is very faint. Ive tried unplugging the unit and it all remained the same...so now im onto the dvd player. when i unplugged the unit cables i realzied that in fact the sound on the tv is fine due to the huge sound i heard when the cables touched....is there a way to fix sound levels on this dvd player??  thanks
Yeah, your remote has a volume control under the audio button, turn it up.  --Bob---
Posted on Nov 14, 2008
There is a faint buzzing sound coming from the 50HDX82 TV. If I turn up the volume of the TV, then one does not hear it, but if you do the '1/2' mute, you hear it a lot, if you mute it completely, you do...
I know this will sound stupid but try it, unplug just power cord, leave it unplugged for 2 hours then plug it back in. This will reset it to factory setting and if this issue was caused by a power issue it will fix it.
Nov 09, 2010 | Toshiba 50HDX82 50" Rear Projection...
I have lost all sound on my tv. You can hear snapping or popping but the sound is real faint on highest setting.
I am sorry to hear about your misfortune. Unless you changed some sound settings right before that happened then the likely cause is that your tv's internal speakers have blown. Which will cause that really faint sound even when the volume is all the way up.
If your TV has an audio out connection you can try hooking it up to surround sound or a receiver with some speakers. You may be able to use your tv this way and get sound.
Otherwise you will have to make use of your warranty if the TV is still covered. If not then there is nothing more I can suggest. Repair cost might be more than hooking it up to an external sound system.
Post back if you have any further questions or comments.Thank you for choosing Fixya.
-Daniel
Oct 17, 2010 | Televison & Video
The volume is on headset. how can i change it to normal.
First, Unplug the Headset from the tv. Then see if you have sound coming from the tv speakers. If not then go into the User menu and select Audio and look for any settings such as "Mute" or "Speakers "on,"off" or sound "off". and select the correct option to correct the issue.
Jul 09, 2009 | Samsung HP-P5091 50 in. Plasma Television
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
No Volume
The earphones input are in bad conditions you need to change it,or try put in the earphones and put out until the picture of the earphones go out.
Aug 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Audio Levels are a mess??
connect a pair of headphones to your telly and see if the sounds is correct at all volume levels.
This will at least tell if you if it is the audio processing or simply the speaker/amplifier section
Aug 05, 2008 | Sharp 25N-M100 25" TV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Philips DVP3960 Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
