Question about Samsung LN-T4061F 40 in. LCD HDTV
I have a samsung lnt4071fx tv. The picture is really messed up. Is it possible that it is a loose connection or is there a known problem associated with the following symptom: picture gets dark, shadowing and picture trails? I have the back off the TV - what can I do here at home?
  • 10,594 Answers
As we discussed in chat session, apparently it is problem of lcd panel (screen) that will be replaced to solve tv problem however t-con board, that is part of lcd panel, replacement might solve picture trail problem.
Click shopjimmy.com for required t-con board.
Thanks.
Posted on Apr 03, 2011
Samsung le32r7 tv picture light levels v low
Reverts eventually means there is some looseness some where. Please check connectors and cables between power supply- TCON, TCON- Panel and main board-TCON. If you cant do it show it to some qualified technician.
Dec 20, 2013 | Samsung LN46A550 LCD TV
I had my lamp go up one day so I replaced it. Ever since then I tv has been really dark. I barely can see the tv during a dark scene in a movie or tv show. I have done everything from adjusting the...
This is actually a copy of the manual. When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components
Jan 16, 2011 | Samsung HLT6176S Television
Samsung ps42p4h1x screen flickers and then goes completely black after about 30 minutes uptime. Sound remains. Tv will work again after about 30 min being off but sane happens have cleaned backboear and...
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 16, 2011 | Samsung Televison & Video
I direct tv picture but no sound
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me. If your connected to a seperate speaker system, attempt to disconnect from that unit and only run sound through your tv to see if that does the trick.
Jan 15, 2011 | Fujitsu P42VHA30WS Television
We have lost the picture on our 42 inch hp plasma tv model pl4260n, we get sound but no picture?? is this a known issue? probably 3 to 5 years old , just happened in the middle of destination truth. nobody...
If it is not a loose connection (internally), it may be most probably related to your picture tube. Check it out and if found faulty get it replaced. If your are in any warranty period (I don't think so since it is 3-5 years old), don't do anything and just inform them, or else you will loose your warranty security.
Apr 17, 2010 | HP PL4260N 42 in. Plasma HDTV
When the TV is turned on after being off over night, or for a few hours; the Tv powers on and the screen becomes filled with a static field and the speakers emmit a loud screeching sound. After a few...
Most likely the main mother board of the TV is the problem. The main board controls everything inside the TV from audio to video and TV program software. There maybe loose connection to the main board or the board is starting to go bad.
Apr 01, 2010 | Samsung LN46A550 LCD TV
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Blinking red light and no picture
The 8 blink condition is a shutdown associated with a sustain voltage, possible that the set only has a loose conncetion, in most cases requires a board replacement, except on the TH-50PX80u, almost always a connection
Sep 17, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Loose Connection for the Green Signal?
Well, first of all, isn't there a warranty on the repair?
It still could be a bad solder connection somewhere but I have seen what is called a G2 / Focus block go bad causing your symptoms.
Working around those tubes is not recommended unless you know what you're doing. You can really mess up the picture or worse, break a tube.
May 18, 2009 | Samsung HCN653W 65" Rear Projection...
Plasma TV color problem
Sometimes, poor picture quality occurs when having activated an A-VHS camera or camcorder connected and having connected another peripheral at the same time. In this case switch off one of the other peripherals. Also, The norcent has a known problem with progressive scan - when connected to a progressive scan source, it yields a distorted screen with dual images and messed up colors.
Mar 22, 2006 | Norcent Technologies2703 27" TV
Samsung LN-T4061F 40 in. LCD HDTV Logo
467 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
