Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Noisy metal clanging sound from badger 5 insinkarator; nothing is in it as far as we can see. please help
Use a vacuum cleaner hose and see if something is in there.
Otherwise, the bearings are going bad or some part has come loose, and motor will eventually slow down and overheat and stop working. The disposal still works and is not leaking, so no harm using it.
There are no repair parts for disposals.
I wrote time/money saving tips for replacing disposal from days when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Posted on Apr 03, 2011
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
It will work but it sounds like metal is grinding in it.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Use vacuum cleaner to see if something is loose.
Otherwise, a noisy disposal that works is functional and not dangerous... but annoying.
Life of disposal is probably shortened since the bearing seal could have failed letting water in, and bearings could be rusted.
Replace disposal if noise bother you.
Gene
May 06, 2014 | In-Sink-Erator InSinkErator Badger 3/4-HP...
My Badger 5 in sink erator is leaking at the bottom of the unit where the electrical wire is connecting tot the metal plate. When turned on, there is a humming noise but the blades do not spin. I have
Thier is an Allen key hole at the very bottom and center of the badger. Try using that with an Allen key. And if it leaks your from where your wires are coming out of your seal is probably bad. Means new badger
Nov 27, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 doesnt turn on
Make sure that the fuse/breaker is not blown/tripped You could take a voltmeter and check for voltage at the unit. Hope this helps
Sep 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus garbage disposal (5-6 years) it humms
Yes, it sounds like you have a bad motor winding, not allowing the motor to actually work. It is time to replace. Hope this helps
Jul 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 removal
If you look at where it meets the sink there is a metal ring up close to the bottom of the sink. stick a phillips screwdriver in any of the three round holes and unscrew it a half turn and it will fall off.
Please rate if this helps-
Mar 22, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
InSinkErator Badger 5hp NOISY
If it were me I would remove the disposal, turn it upside down and see what comes out. Would I run it with something in it making a lot of noise? Absolutely not. If something is loose in it, it could harm the disposal.
Jan 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Weather King 12AJB60a01 - Noisy Clang at Startup like hitting metal lockers
Sounds like the compresser is going out on the unit the noise is internal the winding would not have anything to do with that noise maybe valves going out
May 23, 2008 | Weather King 10AJA2501AH Air Conditioner
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
150 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
