I need a replacement HSI Ignitor. Do you have names of companies that carry this part?
  • Robert Apr 04, 2011
    Hello, you can purchase a hsi at any heating and cooling supply store such at johnstone supply, grainger, etc... Any hvac store will have them.
    Scholar:
  • 133 Answers
HSI stands for "Hot Surface Igniter" and they operate with line voltage, be careful. Grainger or any heating supply house near your location all stock them. Take the old one with you. There are many different styles and shapes but they all work the same way and do the same thing. Please rate this answer for me. Thank you. Roger
Posted on Apr 05, 2011
Thermostat is calling for heat, combustion air motor starts, HSI glows orange, HSI then stops glowing, repeats procedure 3 times, combustion air motor stops, light blinks once What is my...
Hello, Check to see if you are getting between 40 and 90 ohms on the ig niter, just turn off power to furnace and unplug molex connector at igniter. After u unplug igniter check the Resistance of the ignitor and if it is extremely high like 180 ohms or higher than you will need to replace the igniter.
Feb 10, 2011 | Goodman Heating & Cooling
Oven wont heat, shuts down in few seconds
Sseem issue with the thermostatic.
Aug 30, 2008 | Ovens
Goodman GMP075-3 not igniting. Everything cycles as it should but HSI does not glow. Thermostat is set to heat, temp approximately 10 to 15 degrees higher than room temp, blower motor starts, relay clicks...
The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
Nov 02, 2010 | Goodman GMS90703BXA Heater
I have a ge gas dryer mod.#dx4500ge1ww the ignitor comes in and the burner comes on for about 3 min and the burner turns off
have the flame sensor checked if your hsi is the flame sensor replace the hsi (ignitor)
Sep 13, 2010 | GE Dryers
The fan will blow but not in heat mode. The gas heater sounds like it wants to work but there is no heat.
Hello my name is Heath it will be my pleasure to assist you. The problem is probably with the ignition. Check the pilot if its a standing pilot or the hot surface ignitor if it has a HSI ignition If you ohm the hotsurface ignitor and it doesn't show resistance the HSI is shot. If its a standing pilot try lighting the pilot if it lites and doesn't stay lit then the thermocouple could be bad its the rod that sits in the pilot flame easily replaced with a universal replacement that can be found at most hardware stores.
Apr 25, 2010 | Honeywell Programmable Thermostat Heater
WHY DO i get 240 VOLTS ON MY hHSIlead that blows the HSI ON MY lx
You have to have a 240 volt HSI electrode. If you have a 24v, or 110v HSI you will have problems. Check out the catalogue at System Control Engineering to see what I mean. http://www.systemcontrol.co.nz/
Jun 15, 2009 | Heating & Cooling
LARS 2 LITE HOT SURFACE IGNITOR IS NOT IGNITING
I think you could be buying you own HSI part and replace yourself. But I would suspect that the technicians are not being careful when the install the new ones, or someone is getting their hands on them.
But even at that, they are problematic. I am not sure if there are different grades of HSI's either, so that may be the problem too.
They are not that hard to replace. You just need to be sure that it is the as being the cause of the failure.
I would order new ones on the Net, and replace. Just be sure not to touch the HSI, PERIOD. Use only the wrapping that the HSI comes in to hold it, and only remove when all possibility of touching it has gone.
Let me know if you have any more questions. I'll be happy to reply. I somehwat got out of the business as HSI's were coming in, but I do know the right questions to ask, and how to figure out what's happening.
Jan 29, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
HSI ignitor is glowing red but furnace isn't lighting every time
most likely the gas vavle only buy honeywell valve the rest are junk
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Pilot light is on but burner will not come on
You may need to replace the ignighter!...easy fix! or what it really sounds like is your thermastat
Dec 10, 2008 | Goodman GMS90703BXA Heater
I have a Westinghouse Freestyle 472 gas oven that wont light. The igniter seems to start glowing, the fan runs and the grill works but no gas seems to flow.
remove burner see if a hole is melted on glowing ignitor end repair with s/s welding if ok replace ignitor hsi assy w/o old 1 may appear ok but resistance values are out gas valve wont open if still dont work replace valve thermal hsi single should replace both these item anyway.this is assistance advice only do at own risk it worked for me madog cheers.
May 14, 2008 | Kitchen Ranges
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
