Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
I have a Kenmore Upright Freezer Model 253.9280414. It has been in my garage for the last 3-4 years unplugged. I plugged it in to see if it works so that I can sell it. Everything seemed to work for an hour or so (cool air was blowing and the temp was starting to drop). Then it just stopped running and the temp alarm went off. Adjusting the temp does nothing. Light, alarm button & quick freeze buttons seems to work bot the freezer does not turn back on. I tried unplugging and letting it sit for awhile but that did not help. Is it worth fixing to sell or just give away?
buddymcl777
  • 67 Answers
SOURCE: Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Posted on May 01, 2009
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
  • 97 Answers
SOURCE: won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Posted on Jun 17, 2009
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
117 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
