Question about Pride Jazzy 1103 Ultra Standard Power Chair
I need 24 volt interstate batteries for my jazzy power chair. How much are 2 of them?
  • 692 Answers
Well you don't need a 24 volt battery you will need 2 12 volt batteries for a total of 24 volts Contact any local Battery distributor or Interstate battery dealer. You will need 2 U1 sealed AGM or Gel cell batteries and the cost will be $175.00 to $218.00 for 2 batteries. After installing the new batteries be sure to charge before use and then charge every nite for the next 20 days. If you use the chair daily charge overnite If you don't use it daily always store fully charged and charge at least once a week Hope this helps you
Posted on Apr 04, 2011
Is my jazzy wheelchair a 12volt od 24 volt system
There are about 30 models of Jazzy. Which one do you have?
Feb 13, 2014 | Select Jazzy Used Electric Wheelchair
Best battery for 1103 jazzy ultra
MK batteries and/or interstate batteries are top quality. you get what you pay for cheap batteries are manufactured cheaply.
Aug 01, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Is the horn on my jazzy power chair 12 or 24 volt? the horn is so weak that you can barely hear it and i would like to replace it with a roadrunner beep beep horn, but it is 12 volt. and the system on my...
Bob why don't you run a small 2 wire cable from one battery to the armrest where your joystick is located and attach the new horn and a small push button switch to the joystick bracket coming from under the armrest. loosen the knob tightening the joystick bar and pull it out enough for you to attach the horn and button to it. I 'm not sure if that will work because I don't know what the new horn looks like but you can also mount the horn under the shroud near the battery and run the wire to the switch at the joystick. Good luck sounds like an good project
Feb 27, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy Select 6, Charge batteries. Green light comes on...run for a few seconds and goes directly to red light. Chair will continue running. One battery shows a charge of 12 volts the other 13 volts. Has...
Hi You need new batteries If you have a battery store near home or an interstate battery distributor have them get you 2 U1 batteries. Charge before use and you should be go to go for another 3 years or so Hope this helps
Feb 10, 2011 | Pride Jazzy Select 6 Indoor Power...
Are batteries connected in series?
yep they are so that you are providing 24 v dc to power the motors. Your chair should have 2 battery boxes that contain one 22nf battery each and have the connectors that allow them to supply 24 volts to your chair. Hope this helps
Oct 17, 2010 | Electric Jazzy 1115 Power Wheelchair
I need to find a battery for the below listed wheelchair. I live in Houston, TX and need to find a retailer or an online site. Ale?co ? Golden Serial #P2016153 Volt ? 24 Watts ? 180 AMP 10 ...
Yvone You will have to buy 2 batteries for your chair. You need two U1 batteries and if there is a battery warehouse or Interstate Battery store near you they can be purchased there. You can also go through a wheelchair provider but the cost will be higher. Buying on-line might be ok but shipping will be high. Hope this helps you
Sep 30, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
I just gave my mother in law the jazzy 1103 ultra power chair... when you put it on.. the lights flash and the chair creeps along.. it happened all of a sudden.. it wont speed up.. this was donated so I...
tam The batteries need to be replaced. With the lights flashing indicating low voltage and the chair just creeping means weak batteries. With a donated chair you do not know how long the chair sat without being charged. You need to purchase 2 U1 batteries. If there is a battery warehouse store near you or an Interstate battery store check with them because your cost will be less than going through a provider. Hope this helps you
Sep 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy select hasnt been charged over a long period and now batteries are not charging manuel says they may not charge to call provider what will be done can they be charged again?
Virginia sorry no. Your charger cannot pickup low batteries and charge them. You will have to purchase 2 new U1 batteries. If Medicare purchased your chair then they will pay for most of the cost of new batteries. If you bought the chair then I would look for a battery warehouse type store or an Interstate battery store and buy them there they would be somewhat cheaper than buying them from a provider. Hope this helps you
Sep 11, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
195 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
