Question about Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded latest driver no change, what do I do?
  • 96 Answers
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Posted on Apr 11, 2011
Printer ready, Feed option does not working. Other power supply settings printer working properly.
the problem may be in the control panel button itself. the feed button aways works, no adjustments necessary. It's main purpose is to advance the labels.
Jun 27, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Feed option not working but printer ready.
Dear jafar,
just first you conform there is no paper jams in your printer then only i will tell it is motor issue///
Jun 18, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Error condition power supply
Dear,
you have not mentioned, whether print continues with that error or it doesn printer..?
anyway,
first thing, check your power cable.
If that error is on, it means that label media or ribbon sort of errors.
try re inserting both ribbons and media.
if tat error is flashing and printer continues printing, it may coz of over heat of head..! if so try reducing the pressure of the head.
if you are using continous labels, then calibrate the media and ribbon sensor.
for more details, please reach us.
www.trridevlabelss.com
Feb 05, 2013 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Our zebra zm400 is set to ****-off and everything seems fone for a while, then the backing take up roll (rewind) stops rewinding and the backing starts to hang down the front.
Go into the setup menu and check to see if it is currently in **** mode. Or print config to verify mode. If it changes from (****) to tear or rewind, etc. , then the driver is set wrong. Change the driver to **** mode.
Mar 19, 2011 | Zebra 300DPI W/FULL ROLL REWIND...
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
We are printing a label with a logo that is reversed out and the black portion is mottled and not good coverage. We amy be pushing the printing limits
Yes, that is true, but you can take the logo and sharpen it up in a picture editing software. Using the magnifying glass to maginfy and fill in all those holes!
Aug 06, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T Logo
487 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
