Question about Sagem my401x Cellular Phone
Charging Sagem my401c - error
When I try to charge my my401c, with mains or PC, I get an error message : insufficient power, and the charging icon does not change.
Is it me or the phone?
  • Sagem Master
  • 19,396 Answers
Charging errors occur when the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
You can temporarily restart charging by unplugging and plugging back the charger, but on the long run this can damage the phone.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
Posted on Apr 19, 2009
Sony nwz-w262 is recognize by the pc, but it will not charge
I have to assume you are using an USB port. Be aware not all USB ports on a PC can deliver 5 Volt and if they do, it could be the current coming from a port can be insufficient to start the charging ps a modern phone. On an my iPad there is even a message like can't charge from computer as soon as I connect to the PC.
Try an external charger or perhaps just another USB port on the same computer.
Jan 15, 2015 | Sony Audio Players & Recorders
How to unlock a sagem my401c
The safest and easiest way to unlock a SAGEM My401C is to unlock using unlock code. An unlock code for a SAGEM MY410C can be acquired from www.unlocking4u.com/sagem-my401c/rs6wp9/ at affordable cot with easy unlocking instructions.
Sep 11, 2012 | Sagem my301L Cellular Phone
I bought Transcend MP860 last month. when i start charging thru PC it shows the message charging error insufficient voltage.When I finish charging it fully until it displays the message and start playing...
This is a common problem with these players (first link). My MP860 failed in this way (insufficient voltage etc message)
I made a rig with laboratory PSU (several amp output) connected to USB socket and I know that that the problem has nothing to do with voltage (voltage was stable 5V - tested also higher up to 5.5V)
For a while a trick with holding the volume up button worked for me. (see second link) But once I discharged the battery to a too low level and the trick did not work anymore.
My conclusion is that that message indicates Li-ion battery degradation and charger circuit/FW declines to charge it showing misleading message. (battery made by Foxlink)
I tore my the player open and rigged charge circuit and get it working again. Photo: http://farm6.static.flickr.com/5063/5683361395_d59bef8142_b.jpg
Few suggestions: 1. Never allow the battery to be fully discharged. Charge at any opportunity you have. 2. Once you get the Insufficient input voltage message try trick with holding volume adjustment. 3. If 1., 2. failed rip it open and make charging circuit or replace battery. 4. Do not buy Transcend MP3 players. (?)
http://ec.transcendusa.com/forum/viewtitle.asp?BoardID=42&TitleID=915&Page=1
http://www.mouthshut.com/review/Transcend-MP-860-rnlstlqtln
Apr 11, 2011 | Transcend T.sonic 610 MP3 Player
Shaver is not charging. There is power in the outlet, but cannot charge.
1. Check your power cable to ensure that it is 100 percent on both ends any fraying will cause this error 2. Change the power outlet and insufficient power will cause this error 3. Clean out all the old hair and ensure that NO rust exists, this will cause lots of errors 4. Replace the charging cable as the old one may be defective
Jan 12, 2011 | Remington F5790
MY Zen WONT TURN ON. It also wont charge.
Connect the player to a USB port on the back of a desktop PC.. Check the display for the charging icon . As the display times out after a few seconds, press any button on the player to reactivate the display. If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging. If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality.
http://support.creative.com
Jan 16, 2010 | Creative Labs Zen Micro MP3 Player
Fujitsu-Siemens - Batteries won't charge
Whats the spec of your power supply (approx 19v dc @ 3 - 4 Amps...)
Voltage 'OFF LOAD' is irrelevant - its the power consumption (A) that you need to validate (Do not measure directly)
Does the Laptop power up under mains feed ?
Is your concern mainly the fact that the battery(s) are not charging ?
Mar 30, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
SIM LOCK
Where are you located and what company are you trying to use the phone for?
Sep 28, 2007 | Sagem my201X Cellular Phone
Sagem my401x Cellular Phone Logo
237 people viewed this question
Top Sagem Cell Phones Experts
Computer Repairing
Computer Repairing
Pavel Pranovich
Pavel Pranovich
Are you a Sagem Cell Phone Expert? Answer questions, earn points and help others
