Question about Hi-Capacity Sony CCD-V8AF Battery Charger (Equivalent)
Yes, I have a old video camera recorder of sony and the model is CCD-V8AF-E. The video cassette has been pushed down hard and is jammed and the tape doesn't pop up when I hold the eject button down, I've tried tapping the sides but nothing seems to work, how can I get the tape cassette to pop up?
I am looking for a used camcorder to play back tapes recorded on a Sony CCD-TR71. Any suggestions on compatible camcorders? Thanks
your camera uses video8 model cassette, there are so many models in Sony using this cassettes, this type is available in Dubai,
Nov 05, 2015 | Sony Video Cameras
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony Hi8 CCD trv308 NTSC making noise during recording that is audible on playback. Sounds like some moving parts related to turning the tape are not moving as smoothly as they should. Is there anyone...
I had this problem with one of these otherwise very cool cams that I inherited. Something was rubbing on the case of the cassette making a usually faint but audible grinding noise. It is hard to see unless you push the tiny lever on the side of the cassette and flip up the plastic flap that protects the tape. There was a small visible gray grind mark on the center of the case. Now when I buy a new tape I flip open the cassette and carefully scrape away enough plastic on the center of the cassette where it rubs (you can run it a bit and it will grind and show you where) so there is clearance. It worked!!
May 01, 2009 | Sony Handycam CCD-TRV308 Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
I need ausermanual for a Sony Video8AF camcorder Model ccd-V8AF, where do I get one
Its pretty old model of late 80s. Is this CCD-V8AF still working?
Jul 16, 2008 | Cameras
Warning indicator C:32:00/C:32:11
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Feb 05, 2008 | Sony Handycam CCD-TRV43 Camcorder
Hi-Capacity Sony CCD-V8AF Battery Charger (Equivalent) Logo
Top Hi-Capacity Cameras Experts
richie46
Tony Parsons
Tony Parsons
Are you a Hi-Capacity Camera Expert? Answer questions, earn points and help others
