Question about Skil Saws
My skil 3400 vibrates across the floor - Skil Saws
    Habit-Forming:
  • 23 Answers
Quick question before we get into the answer. Does it have the stand with the the rubber feet or not?
Answer(s): The 3400 is a great portable go getter, but it is lightweight. It has a lot of torque for it's size and can do most any job you give it. The model does have an inherent vibration issue. Some more than others. If you don't have the stand, you will have to bolt it or clamp it to a heavy work surface / table. If you got the stand with the saw, it has two cross members on the legs at the same height. This sounds a bit harsh, but the best cheap solution is to get an 8 inch concrete block and bungee cord it to the top cross members on the stand. The weight should dampen the vibration so you can work on smooth surfaces. Use carpet strips under the concrete block to keep it from wearing down your cross members. Best of luck
Posted on Apr 03, 2011
  • armylifer Apr 06, 2011
    If this tip helps you, please rate and vote. Thanks
How do I install new brushes on 15 amp motor for 3400 skil table saw?
http://www.ereplacementparts.com/skil-3400-f01234000a-table-saw-parts-c-130_164_7498.html
Here is the breakdown - I believe the brush tubes just friction fit with the wire connected by a spade terminal.
Jan 14, 2015 | Skil Saws
How do I install on/off switch on Skil Saw 3400
It just pushes in and out. It is held in by plastic legs on the top and bottom of the switch. Reach behind the switch and squeeze on the top and bottom legs to compress them while you push the switch out. The new one will just snap into place as you push it in. Here is a parts diagram if it helps.
Skil 3400 diagram
May 09, 2012 | Skil Saws
Do parts for a model 3305 skil tablesaw interchange with a model 3400
numerous parts should. When you get to the armature and spur gear, then it gets a bit iffy.
Feb 13, 2012 | Skil 10" Table Saw
I would like to down load a manual for a skil 3400 15 amp 10-inch table saw
Try the link below
http://dl.owneriq.net/5/510469e6-b93a-4517-93a8-a670a7ce5782.pdf
Dec 03, 2010 | Skil 10" Table Saw 3400
Can I order from anyone a new fence for a skilsaw fence model 3400.
Skil is part of Bosch Tools. You can go to their website. https://www.boschtoolsservice.com. Click on "Search for your tool" under tool model # type in 3400. I believe the fence you are looking for is part #860 and costs about $34.00, however I would recommend calling them because there were so many variations on the 3400 that there may be more than 1 fence for model 3400 and you want to make sure you get the proper one.
Oct 09, 2010 | Skil F0123400AB Na 10" Table Saw, 15 Amps
I need an owner's manual for Skil 10" table saw. Any help?
What is the model number? Its probably a 3400 model, just call 877-754-5999 and you can have Skil send one out for free.
Feb 17, 2010 | Skil 10" Table Saw 3400
I have a skill 3400. I flipped the on/off button and the motor started and then stopped immediately I figured it was the switch as this happend before but I put in a brand new switch and it still won't...
There is no fuse in the Skil 3400 saw. Check your cord, then brushes. You might have a broken brush spring, causing one brush to hang up in brush tube. Possibly there maybe a lot of sawdust holding a brush up.
Feb 09, 2010 | Skil 10" Table Saw 3400
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
Saws Logo
163 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
