Question about Sharp BD-HP21U Blu-Ray Player
I have a Sharpe BD HP21 (UK version). I updated the firmware to watch Avatar, which worked well. After the player was powered off I have been unable to get any response from the machine at all. The power light comes on and flashes and the display says BYE when it is powered off, but absolutely nothing else. Can the machine be reset in some way?
5 Suggested Answers
bshldn
  • 736 Answers
SOURCE: I have a Sharp BD-Hp20 and i already got the
Make sure that you do have Version HU9071500 installed--->press setup button------>settings-------> version. If it is installed then after you insert Avatar it takes between 8 and 10 minutes before you can select play movie.
Posted on May 11, 2010
bshldn
  • 736 Answers
SOURCE: my blu ray player won't play blu ray copy of avatar
Try completing the update.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
  • 4090 Answers
SOURCE: for avatar how fix samsung bd c5500c blu-ray
If this is a Blu Ray Disk then your unit needs a firmware upgrade to be able to play the new Blu ray format. Contact Samsung for the upgrade file, burn to a DVD and run. The update will allow your unit play the new BR Format.
Please rate my help ++++Thanks for uisng FIXYA
Posted on May 28, 2010
McLindy
  • 32 Answers
SOURCE: I still can't play my Avatar Blu-Ray disk, I've
Disable BD-Live. I have an LG so I don't know the Samsung's setup menu, but you can probably find BD-Live settings in the network section of the menu.
BD-Live is a "feature" that uses your player's internet connection to download new content (e.g. up-to-date movie trailers) every time you insert the disk. While this is pretty cool in theory, it causes problems when (a) you have an internet connection but (b) for some reason the disk isn't able to connect to the server it's looking for.
If you're using an ethernet cable you can essentially accomplish the same thing by disconnecting it from your player before you load the disk. Then the disk will not find an internet connection and won't try to perform the BD-Live functions, which should enable the film to load almost right away.
I disabled BD-Live and that has stopped all such issues (also a problem with Date Night for me). I don't want my moves phoning home every time I get something from Netflix. Maybe some day BD-Live will be cool but for now it's more trouble than it's worth, it seems.
I hope this helps you. Good luck.
Posted on Sep 12, 2010
Testimonial: "Mate you were dead on, I had BD LIVE set to "Allow - Valid only". The combined might of Samsung service, and my local repair agent, had no idea!"
Hi. Just purchased TRON Blu-ray and when start playing the disc, it simple blocks when define the disc language (first menu). Exchanged the disc in the store by a new one, but the problem remains....
Yes,by upgading the firmware should help,but make sure the version in ur Blu Ray player and the ugragable version are the same just higher.Because software firmware can put in one time only,if upgraded the wrong software firmware version that it.The Blu Ray player it is garbage,so be very careful what u ugrading ok.
Jun 18, 2011 | Samsung BD-P3600 Blu-Ray Player
Tip
Bluray Firmware and where to get the latest downloads
bluray player firmware
Here are a list of bluray players and the link to help you get the latest firmwares. I will be adding several players and for some you may need to click on the manufactures link as not all have a direct link for every player.
AMEX
BD-P1-None out but you can see the home page for Amex here
Blucobra
EZ3000-no firmware and it seems the homepage is gone.
BUSH
BD-0-no firmware. Player was sold in England and has been discountinued
Curtis Mathes
CMMBX130
cmmbx72
Daewoo
DBP-1000-None available
Daewoo-2000-none available
Denon
DBP-2010CI
DBP-1610
DVD-3800BDCI
S-5BD
DBP-4010UDCI
Funai
NB500MGXA
NB500MG1F
Insignia
BRDVD
2BRDVD
BRDVD3
BDLIVE01
BRDVD3CA
BRHTIB
NS-WBRDVD
SAMSUNG
HT-BD1250T
HT-BD72000
BD-P1500
BD-P1590
SHARP
BD-HP20
BD-HP21
BD-HP50
I will be updating this all the time and list when it was updated. Please check back and send me a message in the comments section if you have anything to add. Thanks for your help!!!
ver 0.3.2 posted on 7/08/2010-Added several more players and updated links.
on May 18, 2010 | Audio Players & Recorders
I have a Sharp BD-Hp20 and i already got the firmware update and still cannot watch Avatar Bluray please help.
May 09, 2010 | Sharp AQUOS Blu-ray Disc Player
Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
May 03, 2010 | Sharp BD-HP22U Player
Will not play avatar blueray DVD
I have just had this issue, apparently the firmware needs to be updated. I am at 1.38 but there is a newer version (1.65) available. Look at the following link:
http://www.pioneer.co.uk/uk/support/software/BDP-51FD/index.html#download_18
and look at 'Download the update instructions'. This will tell you how to check your current Firmware Version and how to update it if it is required.
Apr 28, 2010 | Pioneer BDP-51FD Blu-Ray Player
Bd hp210 will not play disc (sharp)
I have the same problem but I did download the updates for both my Sony and Sharp Blu Rays and Avatar played wonderfully but unfortunately a few days later both players stop playing all Blu Rays. Has anyone had the same problem?
Apr 26, 2010 | Sharp BD-HP21U Blu-Ray Player
Wrong firmware updated to my Sharp HP20
There is new firmware avalable, try to load right one.
Oct 02, 2009 | Sharp BDHP20U Blu-Ray Player
Sharp BD HP21 Won't recognize USB drives
You have to make sure the files, you downloaded to your USB stick, are not in folders. Mine worked after this. I am still having problems with pixelation on newish discs. I read somewhere that if I plugged a USB thumb drive into the Sharp HP21 it will aid the processing and work better. Does anyone know if this is true as I often get poor picture quality on what looks clean LoveFilm BR discs. (No problems with standard DVDs.)
Sep 30, 2009 | Sharp AQUOS Blu-ray Disc Player
BD-HP21U problems playing discs
You have inadvertently downloaded the US (or other region) version of the firmware. Unfortunately if you try and download the UK version the HP21 just tells you you have already installed it. I was told mine the only way to reset it is for it to be sent to Sharp or you can wait for a new firmware update.
Jul 16, 2009 | Sharp AQUOS Blu-ray Disc Player
Sharp BD-HP21U Blu-Ray Player Logo
279 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
