Question about Xerox Office Equipment & Supplies
Xerox 3535 Magenta out of registration. After replacing the Magenta drum the registration has gone out. Tried doing auto gradation but still no joy. Tried going into diagnostics but after inputting the password nothing happens apart from the touch screen inverting from black and white to white and black. Any ideas....
    President:
  • 2,072 Answers
That has to be resolved with the programs that a Xerox service rep has on a laptop. It is called a Regi Con adjustment. It is a series of adjustments that registers all the colors.
Can't be done via UI diagnostics.
It has to realign the transfer belt, where the image hits the belt and possible the laser.
Doesn't take long, but it is a series only found in the laptop diagnostic tool. Wish I had a better answer. But thats the design intent.
Posted on Aug 05, 2008
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
Lost yellow and magenta in test print
Enter in the service mode and select tes mode select gradation test pattern and make a test for black,cyan,magenta and yellow.If the gradation is not OK you have change the bad imaging unit,or change the developer and drum in the bad image unit + the chip.
Mar 25, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Xerox workcentre 7245 error codes 004-361
Drum motor failure.
If you have a new drum, try replacing the drums 1 by 1 and see when the error clears.
Also make sure the guide rails are in the correct position
Mar 16, 2013 | Xerox DocuColor 3535 Copier
How to replace the drum of dc 3535
remove drum cartridge outside
remove 2 black cap of drum cartridge
then take a small steel rod enough lenght of that drum and put in that hole appear one side of drum
and press it so that other side nob comes outside
again from second side remove the nob of another side
remove all bearings gear
place a new drum and fit all bearing and gear
reverse procedure from downside to up
Jul 23, 2011 | Xerox DocuColor 3535 Copier
Xerox 3535 ero 004-361
Hi
Error code 004-361 means Drum error or Drum motor failure. You'll need to check the drum cartridges, remove the cartridges to check. Now enter DC330 [004-003] and press Start. The Drum Motor will now energize and the drive rotates. If it doesn't then measure voltage between the Drum Motor P/J210-4 (+) and GND (-), it should be +5 VDC is measured. Try measuring the voltage between the Drum Motor. If there is no voltage detected then you'll need to replace Drum Motor (PL 1.1). Hope this helps...
Daniel
Oct 11, 2010 | Xerox DocuColor 3535 Copier
Dc 3535 004-361
you have a problem with color drums motor, try to rotate in a colckwise manualy each color drums, if someone is hard to turn (comapred with a new one) replace it and problem will gone.
good luck
Aug 23, 2010 | Xerox DocuColor 3535 Copier
I have a Xerox DC 3535 with error code 008-900. The fuser is alwais cold, I've tried to change it but problems is still, what can I do ? Thaks, Lucio
This is a static jam, meaning that one of trays or the registration has a stuck flag or bad sensor.
Whit
Item, Inc.
Jan 04, 2010 | Xerox DocuColor 3535 Copier
Reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Nov 25, 2008 | Xerox DocuColor 3535 Copier
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
