Question about Dometic Rooftop RV Air Conditioner
Location of Drain holes on Duo-Therm Model 630035.321
Trying to find drawings showing location(s) of drain holes from condensation pans on Duo-Therm Rooftop A/C Model No. 630035.321
Believe mine has plugged drains -- unit is 4 yrs old and used full time... also as heatpump.
  • Anonymous Mar 25, 2014
    Indoor unit Model number location
  • Dometic Master
  • 6,674 Answers
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Posted on Aug 14, 2008
  • Mike Butler
    Mike Butler Aug 16, 2008
    Update, Probably just holes in that pan, nothing sticking down. Sorry, had coleman in mind. If needed, take cover off and clean from above.
I have a duo therm model 57915 522c1 air unit on my camper. Turned it on and was working fine. Then it shut down. Doing nothing now. Any ideas?
water draining from condensate hole ??? if not its shut off on high water level (you don't want water dripping into your nice camper right ?)
bees are my nemesis on these they love to build mud nests in the drain holes and stop em up !!
Aug 25, 2016 | Heating & Cooling
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
Where is the drain pan located?
Sometimes there is no condensate.
Sometimes the drain line is clogged.
Copy following links for GE Heat Pump water heater.
Expanded drawing of 2012 GE heat pump condensation drain reservoir
Clean the drain line by swinging over head.
Sep 11, 2012 | Water Heaters
Our Duo-Therm RV rooftop AC runs great, but it leaks inside of the motorhome and it's quite annoying. I've read that it could be a problem with the pan. Where is that at and what does it look...
The pan is located under the front coil which is commonly called the evaporator. It collects the water which drips off the evaporator, and usually there is a drain hole located on the roof where the water will drain out in to a hose or some other kind of line. To locate the condensate pan, you will have to take the cover off of the unit, find the front coil, (looks like a radiator) and the pan will be under the coil. Look for the drain on the roof. The drain is connected directly to the pan. The pan could possibly be just stopped up with dirt, etc and may just need to be cleaned out. Other wise it could be rusted out.
Jul 28, 2011 | Heating & Cooling
I have a 1986 Jamboree and the Duo Therm Roof AC is dripping (pouring) in to RV and onto the floor. How can I fix this problem.
You will have to go up on the roof, take the cover off of the unit, and check the condensate drain. It is probably stopped up with dirt, etc. The condensate pan and drain are underneath the evaporator coil which is the "cold " coil. While you are at it, you should also check the rear coil that blows out the hot air on the roof and make sure it isn't stopped up as well. You can clean a condensate pan out with compressed air or maybe even a shop vac depending on the unit. The only other thing it could be is if the pan itself is rusted out.
Jun 23, 2011 | Heating & Cooling
I have a freidrich model cp24e30 ariconditioner I just installed. Where is the drainage plug located
On the condenser / outside left rear corner about 4 incues in from the corner and left side as you look at it there is a punch out hole in the drain pan. The newer AC Units are designed to use the plastic fan blade of the condenser fan to splash water on the condenser and evaporate the water. Most of the time it is not necessary to open this drain hole unless you live in a damp climate where the home constantly has a higher internal humidity percentage. It is however necessary to have the unit serviced at regular intervals for coil and fan cleaning due to the fact that dust becomes a caked up goo over time especially on the condenser coil and the 2 fans.
If you feel that you need to open the hole in the drain pan trhen you will also need to install the 3 X 5 inch external drain catch basin with 3 screws and possibly connect an external drain hose and piping.
Thanks for using FixYa.
Jun 08, 2010 | Friedrich CP24E30 Air Conditioner
My Kenmore refrigerator is leaking water from somewhere on top down into the main compartment. It's also frost free but develops ice sheets in the bottom of the freezer?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of may see ice build up...melt ice with hair dryer/heat will see a pan below evaporator...melt ice in pan...dry water up in pan with paper you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 17, 2009 | Refrigerators
Duo Therm 1500 AC leaking water inside RV after about one hour of cooling. Condenser drain tray is draining OK
On your cold side air coming in, does the ductwork have any insulation on it? Also The evaporator (front part, up where your filter is ) may have a plugged drain tube, depending on year make & model. Not uncommon for some to have a cracked drain pan as well. Your best bet may be to pull plastic cover off unit, then look on side of evaporator housing & see if you notice a tube sticking out side for drainage. It may be plugged if there is one there, use a piece of coated wire or similar and try cleaning it ou, carefully, don't ram it in there and hit coils too hard.. You can remove the 5/16" head screws that hold cover over evaporator, and pull that cover forward & have a look as well.
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
Leaking AC condensate drain pan
Check the drain line for possible plugged trap. Blow back through it in some way to try to clear it.
Jul 05, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
760 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
