Question about Rinnai Heating & Cooling
Rinnai gas log heater (royale) keeps cutting out. now it wont stay on at all. the ignition is fine, the gas flow seems fine and the fan works fine. we vacuum the dust out regularly
    Brigadier General:
  • 4,736 Answers
When you say "it won't stay on at all." Do you mean the burner and the pilot flame shut off together or does the pilot remain lit? Is the unit showing any Fault Codes on the LCD display?
Posted on Apr 04, 2011
Rinnai 32 Hot water system cutting out
The water flow switch is bad but may be able to be adjusted by yo if you closely examine it.
Jun 30, 2013 | Rinnai Heating & Cooling
Have a rinnae royal gas lok heater. Cant start it after gas was shut off. How do you get the ignition to work and start the pilot light again
When the gas was turned OFF, air got in the line(s) and created an air pocket. This air will need to purged from the system, before the heater will light. It only the shutoff valve on the gas line to the heater was turned OFF, it will be easier to purge. If your Rinnai heater has manual ignition rather than electronic ignition. Holding the control down in the Pilot position, will eventually purge the air. If you have electronic ignition, continually trying to light the unit will do the same thing, but take longer to accomplish. Consulting your Rinnai will also help you with this situation.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Rinnai Heating & Cooling
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
I have a rinnai energy saver 556f our power blew out and it knocked out all our appliances.i am trying to get my rinnai to stay lite but the pilot wont stay on.it goes on for about 3 seconds and then cuts...
Patrick,
Your 556 does not have a pilot light. When you try to start look into the window, you should see an arcing, this is the igniter. With a power outage there is no telling what may have happened. With only limited knowledge of a gas heater you should call a Rinnai service guy.
Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Does not want to start
Intermittent faults on these units are very very rare; they either work or they dont! Ive had similar reports that ended up being more of a gas regulator fault (thats the hunk of metal that the small copper tubes from the cylinders are connected to). Do you have any other applainces on gas. When the heater doesnt work try the others'; if they work keep thenm going and then go back and try the heater. Does the heater try and ignite? I also like to recomend getting these heaters serviced occasionally. Just like cars, intermittent faults can be a reminder to get a good service done.
Jul 21, 2010 | Rinnai Heating & Cooling
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Hi i have a rinnai infint 24 and it wont ignite fan is running but doesnt burn what can i do?
is the electric igniter sparking is there voltage at the gas valve, is the gas on ? kinda need to know
Jan 28, 2010 | Rinnai Vent Free Gas Heater/
Rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Oct 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
620 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
