Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
What size replacement prop do I use for my old MotorGuide Power Plus 47lb thrust trolling motor
3 Suggested Answers
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Oct 03, 2016 | Humminbird Boating
Great white wont turn motor runs but wont turn
Do you mean you can hear the motor turn but the propellor doesn't turn?
Then check the break-pin of the propellor. It's a security device that will break when the propellor hits an object in the water...
Sep 27, 2016 | MotorGuide Great White Saltwater Series...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Jul 06, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replacement of motorguide trolling motor prop
Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
Triton72
Mar 26, 2009 | Boating
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Trolling motor will not spin with out being turned by hand.
Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
Nov 29, 2008 | Humminbird 575 Fishfinder
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
52 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
