Question about AudioBahn Car Audio & Video
Got a used Audiobahn A1300HCX amp and Audiobahn bass speaker, and a Sony CDX CA850X disc player. Also 2 Alpine 6x9 SPS-69C3 AND 2 Pioneer TS G650M speakers. I would just like to know where I can get a wiring diagram .
  • bessr2001 Aug 06, 2008
    Thats what I thought I would find here. I guess Ill yard sell it and just buy a new complete system.
    Thanks for the advice.
  • Anonymous Mar 15, 2014
    sony cdx 45u rca only bass from amp
    Problem Solver:
  • 13 Answers
Get in touch with a pro! that lot needs to be fitted properly
good luck
Posted on Aug 05, 2008
Alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
the alpines will take every drop of power from that pioneer and smile... it will sound quite good,and if you ever want to you can actually put about 2x that much power to them 1 of those amps per 6x9 would rock
Apr 08, 2013 | Pioneer GM-3000T Car Audio Amplifier
How should I wire a 4 channel amp for alpine sps 600, 609
they are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Jul 09, 2010 | Alpine SPS-600C Car Component System
Brand new speakers sound blown
it sounds like your problem is bad speakers. I dont think you are under powered. You probley need to take these speaker back if possible. sometimes you will get a faulty speaker, where the wire is glued to cone, the wires are probley not making a good connection. from factory they do screw up. I have had the same problem, it is not noticable by the eye but it does happen. good luck .
Jun 27, 2010 | Alpine SPS-500 Coaxial Car Speaker
Just bought a Sony XPlod CDX-GT150s on eBay. Which of the Sony speakers match it ? Thx
i have this unit, and i have some ministry of sound 6x9 's
look at your unit, and it will say 45wx4
so depending whether you are using an amp, or a sub, basic 50w speakers will be sufficiant. depends what kind of sound you want to produce??
Apr 05, 2010 | Sony CDX-GT110 CD Player
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
Whats the best alpine 6x9? dds-r69g,sps-6939,spr or others
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Feb 07, 2010 | Alpine DDS-R69G Car Speaker
Where to find the enclosures for PIONEER TS-A6872R
get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Oct 07, 2009 | Pioneer TS-A6872R Car Tweeter
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Car Audio & Video Logo
273 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
