No you can't. The turntable needs to rotate the food or the microwave energy will burn holes in your food. The rotation spreads the heat evenly throughout the food. You can test it by removing the turntable and put a plate on the base with a pound of butter on it. Microwave on full power for a minute. Notice the holes?
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
The turntable motor will need to be replaced, the advantage when it is working, the food is heated more evenly when it is turning, but it is not essential to replace.
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and turntable have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, and electronics repair people are not cheap. hope this helps
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable.
An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
