Question about Ovens
Chef regency fan forced oven, i just recently shifted homes and i can not get the oven to work or the clock please help.
award462
  • 395 Answers
SOURCE: chef gas oven user manuals
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
barkencoa
  • 3463 Answers
SOURCE: oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Posted on Dec 07, 2008
  • 81 Answers
SOURCE: Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Posted on Nov 17, 2009
SOURCE: manual for chef select fan
David, I had the same problem. Try viewing this video - it worked for me.
best regards
Bob
http://www.ehow.com/video_7508261_remove-oven-door.html
Posted on Jan 01, 2011
SOURCE: I have a fan forced
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Posted on Feb 28, 2011
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Where can I source a Chel Select Fan Forced Oven Manual from please?
You can try searching for Chef Select online but the age of your oven may make your search unsuccessful.
Jul 28, 2014 | Ovens
My Chef Select fan forced oven has no heat. I have replaced the fan motor and the element, but still no heat. What else could be wrong with it?
Check that it is not been set on automatic. Try turning the timer /clock control through 24hrs and it may go click, fixed
Feb 21, 2013 | Ovens
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
Hope this helps.
Feb 28, 2011 | Ovens
Apr 16, 2009 | Ovens
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 | Ovens
Oven not heating but the fan is working and clock flashing auto
Oct 20, 2008 | Neff B1421 Electric Single Oven
Ovens Logo
251 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
