Question about xheli 9053 Outdoor Volitation Metal Helicopter
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse to forward
  • 1 more comment
  • kenkidd373
    kenkidd373 Jan 06, 2012
    I have this copter. First problem is that it is tail heavy. Remove the canopy. Unloosen the battery bracket and slide the battery as far forward as you can while still being able to plug it in. Retighten the battery bracket and resecure the canopy. This will help. You can also add a small weight to the nose to give it more forward pitch. You will have to work with your tail rotor trim to get it to hover but it will make it more flyable.
  • kenkidd373
  • Jose Severino
    Jose Severino Feb 26, 2014
    REMOVE TAIL ROTOR AND REPLACE WITH A SKY KING TAIL ROTOR MUCH BIGGER THEN IT WILL FIGHT REAL GOOD INTO THE WIND,
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Posted on May 04, 2011
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
How do i replace left rear brake light bulb
1) Open trunk
2) Remove small round plastic access panel with a flat tip screw driver by prying open
3) Remove flat tip screw holding tail light assembly
4) Remove tail light assembly by pulling outward, careful not to break plastic guide/nub
5) Disconnect wiring connectors
6) Remove plastic housing access plate on back of tail light assembly by twisting/turning tabs until they click and then lift access plate from tail light assembly
7) When viewing the the bulbs, the turn signal bulb is the bottom left bulb
8) Install in reverse order, ensuring tail light seal seats properly during installation
Oct 13, 2014 | 1999 Audi A4
Brookstone Helicopter Cloud DSS
In general, the main rotor in an R/C helicopter only tips forward and backwards of vertical center. Direction is determined by the tail rotor. If the entire machine is tilting right, even if the rotor doesn't appear to be, check the motor mount, and or gear train of the main rotor in the fuselage. The main rotor shaft in the fuselage should be exactly vertical relative to the helicopter deck and with trim tabs centered. If your model has the two small fans, one on either side of the fuselage, try replacing the propeller on the right one, even if it looks OK and check for lint or hair on motor shafts. Again, this is a general answer from my own experience. Hope it helps.
Dec 04, 2013 | Electronics - Others
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
My shuang ma 9101 will not fly forward
I had the same problem. The problem is to do with the little cog in the back of the helicopter that drives the tail rotor. If you reverse the helicopter it creates downward movement but if you fly forward it creates lift. This lift can actually cause the white plastic gear wheel to also lift and it looses contact with the drive cog itself. Undo the two screws to lift off the black casing, prize off the white plastic cog and file the underside down slightly. When you put it back in place it now sits slightly lower and does not lift too high when you fly the helicopter forward. Hope this helps.
Jan 27, 2012 | Toys
We have lost our instruction manuals for our rc heicopters. is the small tail propellar supposed to spin? we can't get them to liftoff the main propellars seem to be working fine.
Sadly, Bob is incorrect here. In a coaxial helicopter, the main rotors spin in opposite directions, equalizing the centrifugal force and allowing the craft to hover without spinning, fine-tuned by the adjustment of the trim control. The counter-rotating main blades and internal gyroscopes provide a stable hover, while the tail rotor serves only to push the rear of the chopper up or down, providing the forward/backward thrust. If you are not moving the right joystick, you tail rotor should be stationary, or perhaps moving lazily from the wash of the main rotors. Sounds like a charging issue. What type of charger are you using? Also, Li/Po batteries are not meant to be fully discharged. Fully draining a Li/Po too many times, ESPECIALLY when they are new, will ruin them. Luckily the batteries on an 032 are easily replaceable. Available on Amazon and many other online retailers, and replaced in about 1 minute with only a small screwdriver. With a new Li/Po, charge them FULLY with the correct charger, and always stop the flight as soon as you are having to give it full power to maintain altitude. Also CRUCIAL is you MUST MUST MUST let the battery rest and cool for after a flight, wait a good 10 minutes BEFORE you connect the heli to the charger, and another 10 minute cool down after charging before you fly.
Hope this helps
r
Aug 19, 2011 | SYMA Toys industrial Syma S032 Ready to...
Just purchased new Skyline indoor r/c helicopter. after charging for first time ,turned unit on ,main rotors function properly ,but tail rotor is dead. Did i miss something or is this defective. No tail...
If this model r/c helicopter has two counter rotating main rotors then it does not need a tail rotor.
Tail rotors are used to counter the torque rotation of a single main rotor r/c helicopter.
Jul 02, 2011 | Toys
JD mighty mover tractor, 27MHz, 3 function remote 1. forward/reverse, 2. left & right, 3. loader bucket up/down Problem: no forward or reverse, front wheels turn left and right just fine, loader goes...
My son and I took apart the toy as we have the same problem with ours. The green terminal on the motor moves when we apply pressure to it and the motor speeds up considerably. It appears that a weak or bad terminal is the cause of loss of power. We are not sure how to maintain the pressure on this terminal.
We are going to put it back together and see if it works.
Apr 23, 2011 | RC John Deere Mighty Mover Dump Truck
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Open Questions:
xheli 9053 Outdoor Volitation Metal Helicopter Logo
582 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Sumeet Jha
Sumeet Jha
Tom Chichester
Are you a xheli Toy Expert? Answer questions, earn points and help others
