Question about ASUS A8N-SLI Premium Motherboard
No audio in/out right channel
Right channel speakers have not output.  Speakers are okay, reversed them and they work.  Also, line in only on left channel.  I am thinking I have a loose/broken connection on my built in audio.  How would I go about troubleshooting.  Thanks for any help.  Todd
  • Anonymous May 11, 2010
    I can answer this issue just you will not be pleased about my answer ...
    sorry Todd
  • 112 Answers
You need to check the sound is card is 4:1 or 5:1 or 2:1 set.
Posted on Jan 21, 2009
SOURCE:
VSX-4800 receiver. Why is there no left channel audio output?
It is likely that the left channel output stage has failed but there can be problems with that A + B speaker switching. A defective switch can cut output.
Nov 08, 2015 | Pioneer Audio Players & Recorders
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
Right outputs are not working
The right side output transisters are probally fried, End if you hook up both speakers to the left A&B channel you will do worse damage to it buy over loading it, Over it,s (OHM) Capacity, That mostly causes them to over heat end go up in smoke,
Dec 06, 2012 | Pioneer VSX-D606S Receiver
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
I need to set up 4 pair of speakers, two zones. all ceiling mounted.
Okay! all ceiling mounted speakers. I don't know about 4 pair of speakers.Here is the load down:
First pair of ceiling speakers would be left and right front from speaker A or Main output behind your receiver.
Second ONE,but a pair would be connect to the center channel output as your center speaker.
Another pair would be connect to the surround sound left and right(NOT surround BACK left/right.)
Now,you have 5 channel setup at this point,you still need to purchase a power subwoofer to the SUB PRE-OUTPUT behind your Denon receiver.
For Zone two,you would need to connect your other pair of speakers to surround BACK left and right output.
Go to your Denon MENU button,depending on which model you have,some of them will have an on-screen display feature(you would need to have a composite video cable connect from the video output behind your receiver to the TV video input in order to use the on screen menu.)If not,you would have to it view on the front panel of the A/V receiver.
You need to read the detail on how to setup the video and audio as well as distance and DB for the receiver through the menu button.
I will be frank with you,if you are an amateur,Denon is NOT easy to be setup on the first time.
solutiondoct
Nov 06, 2008 | Denon Audio Players & Recorders
Installation
If you've got a standard 4 speaker system (2 front, 2 rear), your best option is to connect both left speakers to the left channel amp output and both right speakers to the right channel amp output. The only thing you lose is the ability to fade the speakers front to back.
Mar 04, 2008 | Legacy - American II: 2 Channel 1200W...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Open Questions:
AVIRA ANTIVIRUS technical support ${1-8OO~8O3~1O69~} AVIRA ANTIVIRUS Technical Support DWMQYSH AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service number AVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone Number AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service number AVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone Number AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service number AVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone Number AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service number AVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone Number AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service number AVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone Number AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service numberAVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone Number AVIRA ANTIVIRUS Support Number AVIRA ANTIVIRUS Support Phone Number AVIRA ANTIVIRUS Help Phone Number AVIRA ANTIVIRUS Customer Service number AVIRA ANTIVIRUS Customer Support number AVIRA ANTIVIRUS Customer Care number AVIRA ANTIVIRUS Customer Service Phone number AVIRA ANTIVIRUS Customer Support Phone number AVIRA ANTIVIRUS Customer Care Phone number AVIRA ANTIVIRUS Tech Support Number AVIRA ANTIVIRUS Technical Support Number AVIRA ANTIVIRUS Tech Support Phone Number AVIRA ANTIVIRUS Technical Support Phone NumberAVIRA ANTIVIRUS Customer support phone number AVIRA ANTIVIRUS Customer care AVIRA ANTIVIRUS driver support number AVIRA ANTIVIRUS toll free number AVIRA ANTIVIRUS customer care toll free number AVIRA ANTIVIRUS support toll free number AVIRA ANTIVIRUS tech support AVIRA ANTIVIRUS tech support number AVIRA ANTIVIRUS tech support phone number AVIRA ANTIVIRUS technical support AVIRA ANTIVIRUS technical support number AVIRA ANTIVIRUS technical support phone number AVIRA ANTIVIRUS Support phone number AVIRA ANTIVIRUS contact number AVIRA ANTIVIRUS helpline number AVIRA ANTIVIRUS telephone number contact number for AVIRA ANTIVIRUS telephone number for AVIRA ANTIVIRUS AVIRA ANTIVIRUS customer service number AVIRA ANTIVIRUS Customer service phone number AVIRA ANTIVIRUS Customer support number AVIRA ANTIVIRUS Customer support number AVIRA ANTIVIRUS Customer care number number, AVIRA ANTIVIRUS Customer care phone number AVIRA ANTIVIRUS Support phone number AVIRA ANTIVIRUS contact number, top AVIRA ANTIVIRUS helpline number,top AVIRA ANTIVIRUS telephone number, feed back contact number for AVIRA ANTIVIRUS, top telephone number for AVIRA ANTIVIRUS, top AVIRA ANTIVIRUS driver support number , feed back AVIRA ANTIVIRUS toll free number, top AVIRA ANTIVIRUS customer care toll free number, feed back AVIRA ANTIVIRUS support toll free number
Oct 15, 2019 | Avira Computers & Internet
See all ASUS A8N-SLI Premium Motherboard Questions
ASUS A8N-SLI Premium Motherboard Logo
101 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
