Question about Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE FRAME
Digital Frame Model AH1812-B
Memory card was inserted in the wrong slot. Can be heard inside if frame is shaken. It appears that there are four screws in the corners but how do we pull them out to take back off?
Will not come on
Posted on Feb 09, 2011
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How to load pictures to the frame
place images etc in any of the following formats
Supporting formats: jpeg,exif, mov,avi,mpeg1,mpeg4.
on one of the following cards,
Supporting cards: SD,MMC, MS,xD, CF,MD.Remote control. USB, 128Mb integrated memory.
or via usb cable onto the intergrated memory
when connected to pc and switched on will show up like a new harddrive or stick.
move pictures to this drive and they will be on frame internal memory.
or move images etc to sd card or usb stick,
insert card or stick into relevent slot or port on frame and switch on
images should be able to be viewed.
I hope this was useful.
Jan 24, 2011 | Kodak EasyShare SV811 (8858946) Digital...
I received a 7" pandigital
If the photo frame has a slot for an SD card, you can drag and drop the images you want to the card and then insert it into the frame. Connecting the card to the computer can be accomplished by using a card reader or, if the computer has a built-in SD slot, just insert the card.
Jan 21, 2011 | Cameras
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Don't know how to download from my memory card
You can do this one of three ways.
1.) You can insert the Memory Card directly into the Frame
2.) You can connect to your PC or MAC with the camera (Memory Card still inside the Camera)
and Upload the Photos to a File. Then Connect your Frame into your PC or MAC and download them to the Frame.
3.) Connect the camera directly to the frame. (This may cause formatting issues though)
Jan 08, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Pny 4gb sd memory card
HI,
Dear Take this card and format using PC but, make sure PC must have updated antivirus.
This is the best way toreuse this card.
Regards,
Rakesh kumar
Network Support Engineer
Jul 18, 2008 | PNY 2GB microSD Memory Card
Installing memory card in nextar digital photo frame
I had no problem inserting an SD card. Turn the back of the display towards you, insert the Sd card with the label side also facing you. Push card into slot. The card will only go in about halfway.
Dec 09, 2007 | Microsoft Broadband Networking MN-500...
Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE FRAME Logo
1,085 people viewed this question
Top Tao Photography Experts
Phillip Hicks
Phillip Hicks
Vuk B
Tony Parsons
Tony Parsons
Are you a Tao Photography Expert? Answer questions, earn points and help others
